Check t ensure that the fan inside the freezer is working properly if the fan is not working inside the freezer then your refridge willnot get cold also if you pull off the back panel inside the freezer you wil see the holes that the air pushes through to go into the fridge section make sure these holes are not blocked if they are your fridge will also not get cold hope this helps if you need a new fan motor for the freezer try marcone appliance uyou can find them online and they directly mail to your door
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
