Dishwashers Logo
Posted on Jul 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Champion uh1ooB. Water continues to fill tank after the cycle is complete it does not pour in but it is a constant low pressue run
Anonymous
Level 3:
  • Master 8,619 Answers
  • Posted on Jul 13, 2010
Anonymous
Master
Level 3:
Answers
8619
Questions
Helped
2149207
Points
26471
Hi
Thanks for using FixYa. To start with check the water inlet valve which is located behind the lower access panel on the left or right side of the Dishwasher. If the water inlet valve is bad you have to replace it, also check the main water line for clogs/obstructions. If still the issue is not resolved then it’s a bad float switch and needs to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
1helpful
Display reads descale, what can i do to fix this
Descaling the Brewer Mineral content in water varies from place to place. Depending on the mineral content of the water in your area, calcium deposits or scale may build up in your Brewer. Scale is non-toxic, but left unattended, it can hinder the Brewer's performance. Descaling your Brewer helps maintain the heating element and other internal parts of the Brewer that come in contact with water.
NOTE: Do not use water that has been treated by a 'water softener'. The increase in sodium levels in the water can cause scaling in the brewer and hinder its performance.
The Brewer should be descaled every 3-6 months to ensure optimal performance. It is possible for calcium deposits to build up faster, making it necessary to descale more often. This Brewer is equipped with sensors to detect when scale buildup is interfering with the performance of the Brewer. When this is detected, the LCD screen will indicate 'DESCALE'.
NOTE: The Brewer will continue to operate even when the LCD screen indicates 'DESCALE'.
However, if you do not descale the Brewer soon after it is displayed, continued scale buildup could damage the Brewer. If this occurs, 'DESCALE' will begin to flash, alerting you to the potential damage to the Brewer if you do not descale immediately. Promptly follow these steps each time the LCD screen indicates 'DESCALE' to ensure that the Brewer functions optimally.
1. 4459906401_be71bd1933_t.jpg Empty the Water Tank and refill it with vinegar, filling up to the MAX mark on the water tank viewing window. 2. 4459906749_2d2d8c9472_t.jpg Place a 12 oz. or larger ceramic cup (do not use a plastic cup) on the Drip Tray. The Drip Tray and Drip Tray Plate can be removed to accommodate taller mugs and travel mugs. 3. 4460685206_41a39b1eab_t.jpg Select the largest brew size (11.25 oz. serving) by pressing the button on the control panel. 4. 4460685734_41eef702a7_t.jpg Run a cleansing brew without a K-Cup®. Pour the contents of the cup into the sink. 5. 4459906625_e723d37450_t.jpg Repeat the cleansing brew process until the Water Tank is empty, pouring the contents of the cup into the sink after each cycle. Remember to raise and lower the Safety Locking Arm between each cycle so the control panel buttons illuminate. 6.
Let the Brewer stand for at least 4 hours while still on. 7. 4459906401_be71bd1933_t.jpg Rinse the Water Tank thoroughly and fill with fresh water. 8. 4459906749_2d2d8c9472_t.jpg Place a 12 oz. or larger ceramic cup (do not use a plastic cup) on the Drip Tray. 9. 4460685734_41eef702a7_t.jpg Run a cleansing brew without a K-Cup®. Pour the contents of the cup into the sink. 10. 4459906625_e723d37450_t.jpg Repeat the cleansing brew process until the Water Tank is empty, pouring the contents of the cup into the sink after each cycle. You may need to perform additional rinse cycles if you notice any residual taste.
Remember to raise and lower the Safety Locking Arm between each cycle so the control panel buttons illuminate. 11. 4443328562_50d07cb55b_t.jpg Disconnect the power plug from the wall outlet for at least 15 minutes, then re-plug the power cord into the wall outlet. The machine is now ready to use.
NOTE: If the LCD screen continues to indicate 'DESCALE' after completing the process, repeat the 'Descaling the Brewer' process.
Check out this link for support on your unit.
http://brevilleusasupport.com/product/bkc700xl#2044
During the spin cycle water pours continuously like fill cycle
This problem is commonly attributed to either a water inlet valve leaking by, or a pressure switch malfunction. The following link explains how to diagnose the problem:
http://www.fixya.com/support/r3753517-whirlpool_top_load_washer_fills_when_not
I've included parts sources (if required) and how to repair each problem. If you have any questions, please post back and let me know. I hope this information is helpful to you.
1helpful
Coffee is in water is in nothing happens
You may not have enough water in the tank.
Follow these steps
1. With the coffee pot unplugged, fill your resevoir/tank until water begins pouring out of your sprayhead and brew basket.
2. Wait for the water to finish dripping then plug in your Bunn.
3. Let your Bunn warm up for at least 8 minutes.
4. Run a test cycle with clean water, remembering to use the water pitcher provided for this purpose, while leaving your empty pot on the burner beneath the brew basket.
5. If your cycle completed, and your coffee pot is filled to the desired level you are ready to make coffee.
Remember that these Bunn models have no water filter2_bing.gif installed, so, the cleaner the water the better tasting the coffee.
1helpful
2answers
Champion VR7F will not restart without hitting reset switch.
Solved this problem. It required a new motor starter (or at least one component from the starter. The main power lead running to the thermal overload relay had oxidized and was conducting current poorly. Each time it would run ( I did this with the motor starter cover off) the lead going to the bottom side of the thermal overload would spark then glow red during the tank fill. I removed the bad section of wire, and installed a new thermal overload in the starter.
3helpful
Soap in JetDry dispenser.
Unfortunately there is no easy way to completely get the detergent out of the rinse aid reservoir in one quick method, short of taking the inside panel off the door.
However, I would try a simple way to flush it out. With the door open almost al the way open, pour warm/hot water into the rinse aid fill hole and keep pouring until you start to get clear water coming out. The water will be flowing back out the fill hole you're pouring the water into and should just flow down the door panel into the dishwasher tub. Try to keep the door about 10-15 degrees up from all the way open to let the water get in the rinse aid reservoir.
Just pour the water in slowing so you don't agitate the mixture and you should be able to get it running clear in 5-10 minutes. It could take a gallon or so of warm/hot water to accomplish this, but it will flush it.
When you'r done, just put the dishwasher into a rinse cycle to pump out the water and soap, etc. You may have to run a full cycle afterwards to get rid of any excess detergent in the tub.
Hope this helps and best regards!
Low detergent light does not come on indicating the GE profile dishwasher is out of detergent.
It is probably because your Smart Dispenser is full of water and there may be a clog of some type in the pump. Try purging your Smart Dispenser and see if it fixes the problem!! It fixed ours!!
How to Purge Smart Dispenser
The purge routine operates the bulk dispenser pump continuously to drain the bulk dispenser tank when an incorrect liquid was poured in the tank. The process consists of setting up the dishwasher to run the purge mode, running the purge mode and then cleaning up the purged detergent.
Follow these steps carefully to have a successful purge run.
For Top Control Models:
  1. Make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  2. Press Heated Dry and Down Arrow buttons together for 3 seconds. All LEDs will illuminate.
  3. Press Added Heat and Up Arrow buttons together for 3 seconds. The Anti-bacteria LED will illuminate
  4. Press Start button one time
  5. Select Normal and make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  6. Press Start button one more time and dishwasher will run a complete cycle without the main motor running. Cycle is complete when the Clean light illuminates. This should take approximately 60 minutes.
  7. Open door and wipe up excess detergent from the door and tub
  8. Flush remaining detergent off by pouring water on the door and tub where there is detergent residue.
  9. Remove SmartDispenser cap and fill tank with water and then replace cap.
  10. Repeat Steps 1 through 9 one time.
  11. Then, repeat Steps 1 through 6. When the Clean LED illuminates, the system is purged and ready to be refilled with the correct detergent.
Front Mount Controls (same as above except for the changes in the two below steps):
2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
XP7230 does not work with Claris F088 filter cartridge installed
You have the filter screwed it too far. As soon as you feel the filter seating do not screw it in any further.
2answers
Frigidaire dishwasher not completing cycle.
hi,
The cycle doesn't complete
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
On some units, the pause is timed and the unit continues after the allotted time.
On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
I see an error code
If your dishwasher has a digital readout and you see an error code, it may indicate a problem with the unit. If this happens, look up the error code in your owner's manual to find out what the problem is.
Good Luck
Jan 03, 2009 • Dishwashers
Champion dishwasher
if you turn the unit off from the circuit breaker will the water still run?if so the guts inside the solenoid valve are worn.you can call champion and get a kit to replace the worn parts and its not difficult to do.hope this helps.
Nov 07, 2007 • Dishwashers
Top Champion Dishwashers Experts
Mike Cairns
Mike Cairns
Are you a Champion Dishwasher Expert? Answer questions, earn points and help others
