Dvd recorder remote control
Anytime your unit displays RC1, 2, or 3 - the remote code needs to be reset. Other messages are "chk remote n" or "set n", n being the number 1, 2 or 3. These remote codes are set in case you have multiple products that interact w/ the remote - so when operating one device the other doesn't interfere. Unfortunately, every now and then for completely unknown reasons, they can slip out of the proper code. All you have to do (if your remote is, in fact, functional) is press and hold the number on the remote that corresponds with that which displays on the unit - in your case the number 3, and hold the Enter key at the same time for about 5 to 10 seconds. This should resume operation shortly thereafter. However, you will not see any confirmation on the display as you are performing this reset. It is trial and error.
Hi, my remote does not have a Enter key. Do you mean the Return key? But I hold the #1 key and the Return key for 7 seconds it Do Not work. Can you help. Thanks.
