SanDisk Sansa Clip MP3 Player Logo
Posted on Jul 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a question about recharging a SanDish Sansa clip MP3 player. We use the supplied USB cable attached to our PC to recharge the unit while at home. We also just got a car (12 Volt input) cell phone charger that has an adapter that will fit the Sansa clip USB input. What we are asking is if it is OK to use the cell phone charger to recharge the Sansa clip batteries while traveling in the car? The cell phone charger is a model SKU 03045 made by Just Wireless. It states 12 V input with no output listed. Thanks for any help with this question. If you need to contact me use [email protected]
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • SanDisk Master 102,366 Answers
  • Posted on Jul 12, 2010
SanDisk Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443165
Points
622693
If the USB end of the Sansa cable connects to the charger, then there's no problem.
How to recharge ematic esport clip using USB cable
You can charge it connected to your computer or buy an adapter that you can plug in the outlet for an mp3 player.
It comes with a USB to recharge on PC, you cannot recharge in iPod stand. I believe iPod has the market on this.
Can I recharge the battery of my Sandisk Sansa Clip MP3 player without using my computer?
Yes. AC to USB adapters are available anywhere cell phone chargers are sold. One end plugs into a wall outlet and you can plug the USB cord from your Sansa into the other end. I use such a device every night to charge my Sansa.
2answers
Does sandisk sansa m240 have a rechargeable battery or can i recharge it thru the USB..
Hi There
For this issue i would say the best solution is, you can use the USB cable, thats the best solution rather than using the rechargeable battery.....
1helpful
Rechargeing a sansa mp3 player
Sansa MP3 players recharge via the slot on the bottom. Use the supplied cable, plug one end into the player and the other into a USB slot on your computer. Make sure the player is unlocked before connecting.
Cables to conect to computer
This recharges when connected to the USB port of your PC. SanDisk does sell a wall charger separately, visit a store with your player to locate one. If you are missing your USB cable you will need to order a replacement for both charging and transferring music anyways.
1helpful
2answers
My sansa fuze wont charge
Some USB ports cannot supply enough power to charge the Fuze. I had the same problem. I worked around it by getting a wall charger from RadioShack.
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
1helpful
How do you recharge the battery and download i tunes from computer (apple)
The Sansa Clip uses an internal battery that is charged simply by using a USB cable and pluging it into your computer.
you can download iTunes here. (it will start automaticly)
Charging the battery on a sansa mp3 player
recharge it by plugging it in to the USB port. your sansa should have come with a USB cable and the ports are pretty easy to find.
almost all types of earbuds or earphones are compatible with the sansa system, so if you just go out and buy some you should be fine.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
