I suspect that your 6 cd changer is having the fault. The error indicates always a system malfunctioning. From our point of view we can probe into for a solution by the following guidelines.
first of all open the 6 Cd changer from the top. look within to find that the changer is jammed inside. If so slowly tapp while you switch on the power. if the jamm clears and the changer ejects, then open out all the cd's present in the changer for any damage due to heat. If this did not solve, clowing chek for foreign particles/dust that has blocked the loading drive.from completing the cycle so as to reset the mode. normally all errors show because of the processor not receiving the complete cycle signals. hence check for all the moving parts, the drives and the loading mechanism. check also for any linkage damge, any leadd specially flexible line wiring to the motors for an open circuit. Slowly turn the motor drive to intiate to confirm if the motor has failed. Altogether use a multimeter and check in all the sections described.
I hope this helps. Good day.
