Breaker box clicks on then air becomes warm. I have tried everything. It seems as though when I change the temperature on the thermostat then the breaker clicks on. I thought at first I may have needed some freon, not the case. Electrician came, breaker is good. Put in a new capacitor, same thing happened. Breaker box clicked, warm air. I want to know if the inside thermostat have anything to do with the breaker and then the arm air.
When you say breaker box clicks and then warm air, are you referring to the actual breaker switch in your power panel, or clicking at your ceiling assembly? When the breaker trips, the air conditioner should shut down completely, is that what happens? The compressor kicking in and out could cause circuit breaker to trip. Did the electrician record incoming voltage supply, and what was it ? 115 volts?
