LG LHD45EL Dehumidifier Logo
Posted on Jul 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LG LHD45EL Dehumidifier - The dehumidifier runs continuously, but very little moisture is taken out of the air. There is only about one quarter of a tank of water after running continuously for 24 hours in a very humid environment. Also, the unit sounds like it is laboring/struggling to run
Anonymous
Level 3:
  • LG Master 43,501 Answers
  • Posted on Jan 27, 2011
Anonymous
LG Master
Level 3:
Answers
43501
Questions
0
Helped
10834924
Points
101584
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
My LG LHD45EL Dehumidifier can't collect water in bucket, which part is failure and how to repair it?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Our dehumidifier is about 2 years old. It turns on and sounds fine, but it no longer condenses any moisture from the air. Does the refridgerant need rechargeing?
heatman101
Our LG LHD45EL 45-pint Dehumidifier is not collecting water. The fan is running, and there isn't any error message in the display. I have tried unplugging it for a while to see if it would re-set....
heatman101
Hello, my dehumidifier has a problem, it functions but it does not withdraw water in the tank, it functions without stop and moisture do not go down? it does not have there water in the tank. how to cure...
heatman101
Lg dehumidifier does not pick up any water or humidity?
heatman101
My LG LHD45EL all of a sudden
Short on refrigerant... or a failed compressor. are most likely or a system problem, causing it to trip off.
There may also be a failed electrical component, you need to check for voltage at the compressor.
cheers
The dehumidifier is running but pulling in very little moisture
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
1helpful
The dehumidifier isn't taking the moisture out of the air.
is the compressor in the unit hot to the touch,or are the coils freezing and thawing when it runs<if so you probably need to add some R-134a refrigerant,these type of units are notorious for losing all or part of their refrigerant charge,but unless you have the equipment to remove old refrigerant and vacuum the system down and recharge it it can get costly
1helpful
No water is collecting on 2 year old lg humidifier
If when you turn your dehumidifier on the compressor runs then you should get moisture. Dehumidifiers work on the same principal as refrigeration. There is a bad control switch or the compressor start relay or capacitor is defective. If compressor runs and there is no effect then that is another problem. The filter should come out the front where the air goes in front and the filter should be washed by hand in warm degrease detergent water, dry and replace. If the disposable type filter I will help you contact LG.Thanks, Sea Breeze
Top LG Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
