Hi, I got ten years old Jacuzzi whirlpool Mod. Z112 SPA. I get "SN" blinking and nothing works. I did check the Motor and it is OK,
I checked by Owmmeter the 2 temp sensors and they show ~26K (when cold) and when I warm them they get down to 25K, 24K ect.
thank you
Moshe
SOURCE: Hello, how I remove the water from my whirlpool
hook up a garden hose to a faucet. Put the other end in your spa. Then turn on the faucetuntil water comes out the spa end of hose. Make sure the end in the spa is weighted down so it doesn't come out. Then remove the hose from the faucet and keeping it lower than the spa lay the hose where it can drain with causing problems. The water will flow on its own draining the spa. You may want to clean it while its draing so the dirty water will be diluted and drain at thhe same time. Make sure the water is not drained out around any electrical AND!!! NO DIVING!!!! If you lose the prime, just fill the hose again with the faucet. Good luck
