HP Pavilion TX1000Z 12.1" Touch Screen TABLET NOTEBOOK LAPTOP PC PC Notebook Logo
Posted on Jul 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hp pavillon tx1000 12.1 inch touch screen cursor stays at bottom left hand conrner
Vincent G
Level 3:
  • Master 2,363 Answers
  • Posted on Jul 11, 2010
Vincent G
Master
Level 3:
Answers
2363
Questions
Helped
1032352
Points
5917
Clean the screen with a clean soft cotton cloth is the step #1
Step 2:
SEE FULL instruction HERE
Calibrate the touch screen
The command buttons and fields are displayed on the screen image at specific pixel points. To initiate a response, the touch screen interface needs to recognize exactly where a fingertip or pen touches the screen relative to the pixel position of the display. Each user has a slightly different hand-eye coordination response. Calibrating the touch screen allows the interface to compensate between where the program is expecting a touch and where the touch actually occurs. To calibrate the touch screen, place the tablet notebook in the desired orientation and do the following actions.
  1. Click or tap Start > Control Panel > Tablet PC Settings to open the Table PC Settings window.
  2. On the General tab, select the option to display the menus in either the Right-handed or Left-handed position.
  3. On the General tab, select the desired screen orientation from the drop-down menu, and click or tap Calibrate . Follow the instruction to touch the screen at the specified points. Repeat this calibration action for all four of the screen orientations, then click or tap Apply .
  4. On the Handwriting Recognition tab, select the Use the handwriting personalization option.
  5. At a later time, you can return to review the Go to Pen and Input Devices and Go to Input Panel Settings options to make using the touch screen to control programs and input text easier and more accurate.
Compare your version of the firmware to the latest one at HP offical site HERE
Always get the latest firmware to avoid problem.
Always keep the screen clean!
3helpful
Turned back light down on my polaroid 4GB pmp280-4 touch screen now i cant see to turn it back up
settings is in the lower right hand side of the screen, tap there.
display is in the middle of the screen on the left hand side about one(1) inch down from the top of the screen.
the slider for brightness is down one and one-forth inches down from the top of the screen, tap about 1 inch from the left hand side of the screen, remember it is 1 1/4 inches down the screen.
NCMB
1helpful
HP TX1000 Tablet The cursor on my screen keeps going to the bottom left hand corner and stays there. The problem remains even when I used a USB mouse. Anyone knows what the cause?
click start button in lower left hand corner, then a pop out menu will come up, click control panel, then find mouse, click it, then go to pointer options and click it, see if theres a box checked that says something like (automatically move pointer to the default button in a dialog box). uncheck that box......hope this helps you.......
Cursor jumps when typing
since you laptop mouse is touchpad. when you starts typing, your finger(hands) touches the touchpad which throw the cursor away. Make sure, while typing your hands does not touch the touchpad of the laptop.
1helpful
3answers
Asus notebook K501J Model. A blue wall at bottom of screen, about two inches high screen' .I cannot remove same. Also I cannot get the task at bottom of screen,
Try this:
Place your cursor at the top of the wide blue band. See if the cursor arrow changes to a 2-sided arrow. If if does, hold down the left button and move the cursor down until the screen is again normal.
Basically what you have done is to take part of the window and increase the size of the bar. This actually should be the taskbar, but it's way too large.
HP Pavilion dv6337us screen problem
Place you cursor on a blank spot on the black area, Hold the left mouse/touchpad button down and drag it back down to the bottom of the screen. That should get you back to where you want things to be.
If that fixes it, please return here to rank this as solved. If it doesn't, let me know and we'll see what else we can come up with. ;o)
Ron-
3answers
ZD7020US Display
sounds like you have the wrong monitor drivers installed,  download updated monitor drivers from the manufacturer's website,
also check your display settings,  as something is really wrong there.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
