Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
Posted on Jul 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Boat does not plane
I have a 2003 Tracker boat. Model ProGuide V16 with a 2003 40hp Mercury 2 stroke. I recently acquired the boat as a gift. I tested the boat out with a full tank of gas and myself (180lb). The engine did not have enough power to achieve plane. The RPM showed 5000 RPM, the max for the engine is 5500 RPM.
Should the engine have enough hp to achieve plane?
Steve P
Level 3:
  • Light Master 3,912 Answers
  • Posted on Nov 12, 2021
Steve P
Light Master
Level 3:
Answers
3912
Questions
5
Helped
1307679
Points
15904
Try a 75HP or larger motor... take the boat to a good prop shop and they should be able to advise you of the correct prop, close enough to get you going as well as possible.
paul
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Light Master 1,190 Answers
  • Posted on May 30, 2014
paul
Light Master
Level 3:
Renaissance:
Answers
1190
Questions
Helped
264220
Points
1883
The engine is a bit small but make sure its fully tilted down on the tilt pin adjustments ! how much gear or fuel tanks etc are at the rear of the boat and do you sit central of boat with steering and remote gear/throttle controls or at rear , weight moved forward will help and you could also fit doel finns to the cavitation plate above the prop which looks like a dolphins tail and these will increase lift and get you on the plane ! really a bigger engine like 75hp would be the answer ! what max hp rating is the boat ? try the above first and any more info you can give me would help give suggestions !
Ian Summerfield
Level 3:
Master:
  • Master 502 Answers
  • Posted on Jul 10, 2010
Ian Summerfield
Master
Level 3:
Master:
Answers
502
Questions
0
Helped
133871
Points
1385
You could try a lower pitched prop.2" would up the revs by 400 revs.,which would up the revs ,but give you more low down thrust,and/or tucking the motor under more[if you have electric trim/tilt].thats a big boat and fair bit of weight for a 40hp..my 40hp merc is on a 13ft saracen,and with two of us it takes a while to get gooing.so i bought a ProPulse prop,with adjustable pitch.been god to try different pitches
What is the weight and length of a 2005 Mercury 2 stroke long shaft boat motor?
Depends on the HP of the motor. The long shaft will only ad a few lbs. See this link for motor specs on weights.
https://www.nadaguides.com/Boats/2005/mercury/outboard-motors
2helpful
2answers
What to do to get boat to plane out
Try adding a plane to the lower unit of the outboard motor.
SE Sport 200 Hydrofoil
This will plane out the boat quite well.
Jan 05, 2015 • Boating
I have a 1984 glstron boat wit a 70 hp motor with a 13x15 pitch prop. and have to play with the power trm to get boat to plane out. How do I know if I have the right pitch prop.?
You do not tell us the size of your boat. I sounds as if you have the motor set too high in the transom. Does the motor just rev up and not move the boat or does it lug down and not seem to have enough power? More info, better ideas.
9.9 mercury 2 stroke #1 coil green/ white or green/yellow
You have some luck looking around the Mercury section of the boating forums.
http://forums.iboats.com/mercury-mariner-outboards-25/
5helpful
I need wiring diagram for boat 1993 Bayliner jazz engine: mercury 90 hp 3 cylinder 2 stroke jet serial no:oeo31008
can't start my 1993 bayliner 1400 jazz. replaced key switch, kill switch today. I got the boat last week running.
Sep 24, 2009 • Boating
3answers
Outboard problem
Check your prop...probably slightly bent and only is noticeable at higher rpms.
Top Light Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
john h
Are you a Light Boating Expert? Answer questions, earn points and help others
