Question about Lexar 64MB FLASH MEMORY DRIVE USB 2.0 - (JDCL064231) Hard Drive
How do I empty the Lexar memory stick to create more room?
I've loaded all sorts of stuff like: pictures, music, papers, projects, etc. on the lexar memory stick that has 16GB. and now I'm trying to load more pictures on it, but it said it was full so I highlighted everything and dragged it to the trash but it still says it's full and there is no room. how do I empty the Lexar memory stick so there is more room?
  • 2,571 Answers
If you have moved everything off it, just right click and choose format.
You can do this from my computer, or disc managment (right click my computer/manage/disc managment)
Posted on Jul 10, 2010
SOURCE:
My sony cyber shot camera suddenly is saying that my Lexar 4GB CompactFlash Premium Series 80x needs to be formatted. What about my pictures?
You might have locked memory card. If not first try to connect memory card to PC with memory card reader and try to copy your stuff... then after you take all stuff try to format it.
Sep 16, 2012 | Lexar 4GB Professional Series 80x...
Lexar 8GB wont work. when i insert it, it shows up on my computer as connected but then when i click on the lexar icon to view my files on it, it doesn't open, the message: 'please insert disk into drive...
Some computers will not support a large 8GB stick. The best some will do is 2GB, If you are running a computer pre-2001, you may not be able to use the 8GB stick (I have the same problem with my desktop PC). It just is not supported!
Oct 05, 2010 | Lexar Professional High-Speed 2GB Secure...
Plugged in memory stick,coputer said ready for use,what do i do next to start process and put my pictures on it,as there were no on screen instructions as what to do to get...
The computer see the Lexar as a external storage device.
Just click on My Computer and you will see the Lexar as a E drive or some other drive letter. Double click on this to open the drive. You can create folders on this drive and copy and paste files to this drive or to the folders just like copying and deleting files on the C drive.
Sep 09, 2010 | Lexar Computers & Internet
Have windows xp I need a driver for a lexar 2.0 4GB
No driver needed, when plugged in it should just appear in My Computer. If it doesn't that means the memory stick is dead, junk it.
Jul 11, 2010 | Lexar JumpDrive Classic Portable USB Data...
When I plug in my Lexar memory stick, and try to save a file to the removable drive (J) which is the memory stick file...it says I can't because it doesn't exist. Help?
Hi, Neil.
Look in "My Computer" to see if another drive letter was created when your memory stick was plugged in. Sometimes, another drive letter is created. Try dragging and dropping the file you want to save.
In case you are not aware, in each computer, the drive letter for a memory stick could be different, depending how a computer is set up.
Also, try in another computer to see how your memory stick works (if it's OK).
Hope this helps.
Oct 25, 2009 | Lexar JumpDrive Classic Portable USB Data...
I have a windows xp and a lexar microsd 4gb adapter
Hi If your card is SDHC version is possible that you card adapter doesn't support it, you have to try another one.
Oct 19, 2009 | SanDisk 2GB microSD Memory Card
Lexar memory stick
This device should be plugged into any computer that has USB ports to plug into. Usually, you plug it in and you will see something pop up in the bottom right corner of the screen about installing usb drive. When it is done installing (usually takes about 1 minute), you can open My Computer and see it in there as a removable drive. Open it and save your files directly in there by copy and paste or drag and drop.
Thanks,
Lolita
Mar 18, 2009 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
Transfer music from computer to lexar 1gb
You just need to connect the Lexar 1Hb to the USB port on your computer and let the computer recognize it and then after that double click Mycomputer and you should see there the Lexar , just double click on it and now you can copy and paste music from your computer to the Lexar...
Jan 02, 2009 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
Saving emails to lexar memorty stick
Copy and past
You copy the mails and past them on the stick
Good luck to you
Dec 28, 2008 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
Lexar 64MB FLASH MEMORY DRIVE USB 2.0 - (JDCL064231) Hard Drive Logo
1,288 people viewed this question
Top Lexar Computers & Internet Experts
Colin Stickland
Colin Stickland
gggg
CarlosIjalba
Are you a Lexar Computer and Internet Expert? Answer questions, earn points and help others
