As you have not
specified which code you need i am hereby giving how to
get all of the codes:
NETWORK UNLOCK CODE:
You
can unlock it by flashing your mobile if your mobile is a CDMA
mobile...
The procedure for flashing your mobile is in the link below
http://hubpages.com/hub/How-to-Flash-your-cell-phone
It has an video explanation.
If your mobile is not an CDMA
mobile , you can get the network unlock code(NUC) by just
contacting the current network provider customer caredepartment.It is
free of cost.
Therestrictioncodecan be got from your old service
provider..This restriction code iskeptto prevent someone who stole
themobile from using it withanotherprovider...
They will have a
security check done with your date of birth etc..to verify whether you
are the exact owner of the phone..
After that they will provide
you the restriction code to unlock it and use it with another service
provider..
It is all free of cost donot pay anyone for this
seeing some advertisement over internet . That is all fake ads.
The
above proceudre works and you can verify that by seeing the rating of
an happy customer here..
http://www.fixya.com/support/t4035818-need_unlock_nokia5130c_2_use
PUK CODE:
PUK
code can be given only by your service provider which is specific for
each and every mobile number.
Contact
your sim customer care department over phone. Its free of cost
to get the pin or puk no. If you cant contact through your phone get
some other phone and contact them.
Go
to the nearest service outlet of your service provider they can also
help you.
There is no other go than the
above procedure only your service provider cangive it nobody else in
this world nor any software.
Go
to the below link and you can confirm that the above procedure works
and there is a testimonial given by the customer too. http://www.fixya.com/support/t3582685-phome_lg_ke670_put_security_code_phone
PIN CODE:
HI
If you are asking for pin contact your service provider , he will give
you a default pin .
If
you try pin more than few predefined no of times your phone will ask
PUK code which can also be given only by your service provider which is
specific for each and every mobile number . Do not try PUK(new pin code)
code many times or else your sim will be blocked and you will need a
new sim.
Contact your sim
customer care department over phone. Its free of cost to get the
pin or puk no.
Go to the nearest service
outlet of your service provider they can also help you.
There
is no other go than the above procedure only your service provider can
give it nobody else in this world nor any software.
SOURCE: unlocking a motorola razr for free
You will need to try online at unlockitnow.com or mobile2mobile.net or take the phone to a mobile service center to have it unlock there.
SOURCE: free unlock motorola v3 razr codes
my phone does not accept sim used in lesotho snce after registering in africa and it my100x sagem
SOURCE: need pin code to unlock motorola v3 razor please
I HOPE I CAN ANSWER YOU BECAUSE I MET THE SAME PROBLEM WITH YOU
SOURCE: How can I unlock my Motorola Razr V3 subsidy code?
hi you can get the unlock codes from here
http://www.wickedunlock.com/motorola-razr-v3/rs11wp9/
they provide codes at reasonable cost.
SOURCE: how to unlock motorola razr v3 without knowing the
You can unlock your mobile yourself at home to unlock your Motorola model mobile using codes are the best way , why i am saying codes means to unlock your mobile with codes are simple & easy way,
Get the unlock code from this site http://www.onlinegsmunlock.com/motorola-razr-v3/rs7wp9/ ,it has the best instructions and simple ways to unlock your mobile from the network lock...........If you unlock your phone using the unlock code then your phone gets permanently unlocked....After that, you can use it with any other network's sim card...........
It is not safe to enter free
unlocking code to your Motorola RAZR V3 cell phone because it leads to data lost and it can damage your phone. So buy
reliable unlock code by RAZR V3 UNLOCK CODE provided with unlocking instructions.
Cheers!
