Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+965+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DQ965GFWindows 7 is not a supported system, but you can use the drivers from the vista system, but only the 32 bit.
Turn on or restart your computer and watch for a message during the post about a particular key, usually
Del or
F2, that you'll need to press to
...enter SETUP. Press this key as soon as you see the message.
After the post,
BIOS will attempt to boot from the first device listed in the boot
order.You need to change that, so the first boot device in the list is the dvd drive. If that device is not bootable, BIOS will attempt to boot from
the second device listed, and so on.
Note: The boot order is a BIOS setting so it's OS independent. In other words, it doesn't matter if you have Windows 7,
Windows Vista, Windows XP, Linux, or any other PC operating system on
your hard drive or other bootable device, these boot sequence change
instructions will still apply.
Here is how you do this:
http://www.hiren.info/pages/bios-boot-cdromBut ofcourse there could be a problem with the dvd drive or harddrive.
To install windows 7, you will need at least 1 gb ram or more, and a dual core cpu.
Best of luck
