Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
Posted on Feb 15, 2018
My passport 5oo Gig freezes my computer
My external drive (WD Passport 500g) worked fine for a year, then on day just locked up my computer. I tried it in several different computers, with several different cords and each time it locked up the computer until i disconnected it. Is there any way to recover the information on it?
thegu99
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on May 10, 2018
thegu99
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
Helped
1913
Points
5
Yes there is. Please note that removing the drive from your external will likely void any warranty you may have with the manufacturer.
If ok with that, remove the drive from the enclosure very carefully. Then connect the internal drive directly to a SATA connector, do not use USB and see if able to access drive. If so, backup data right away.
If this model is only USB connector, or if still not accessible when connected to SATA, then you will need a reputable data recovery service provider.
5 Related Answers
A
Anonymous
  • Posted on Apr 29, 2008
SOURCE: dropped a WD passport drive, now it won't load. HELP!
Unfortunately, these drives are not made to be dropped.
It sounds like it was damaged by the drop which could have rendered the read/write heads inoperable or mis-aligned.
Contact Western Digital for a warranty replacement.
A
Anonymous
  • Posted on Sep 01, 2008
SOURCE: My PC is not recognizing my WD Passport 120GB USB external drive.
These WD Passport external drives are junk. This happened to two of mine, switched to Maxtor.
Anonymous
  • Posted on Jan 02, 2009
I had the same issue. Its not a power issue because it shows up in device manager. Heres what I did.
Right-click on my computer and click Manage>Disk Management
Your drive should show up there. Right-click on it. If explore is not grayed out, assign a drive letter to it and you should then be bale to see it in my computer.
In my case explore was grayed out. I had to click on the option to format the drive. After re-formatting the passport explore was available. I then assigned a drive letter to it and I have access again.
I guess somehow using it on multiple computers srcewed up the file-system on it. I was using it between windows and linux.
This fixed my problem.
Anonymous
  • 109 Answers
  • Posted on Dec 24, 2009
SOURCE: How to format WD Passport 1TB to FAT32
Plug the drive into your PC.
Right Click on My Computer (or Computer in Vista/Windows 7) and select Manage.
Click on Disk Management.
Right Click the Volume in question and select Format. Select FAT32 in the options.
Anonymous
  • 10406 Answers
  • Posted on Nov 11, 2010
SOURCE: How can I install the driver for My Passport WD
It is a "plug-and-play" device, and Windows XP/Vista/7 are "plug-and-play-aware" systems.
So, just connect it, and Windows should recognize it.
Are you getting any error-messages?
What is happening?
What is not happening?
3helpful
2answers
WD 500G HDD suddenly un-readable; changed name to local disk, says I need to format in order to use it. I have tons of important stuff on there.
Could you confirm if the problem with the drive not being recognized is a problem with the USB cable? I have a 250GB passport and it worked fine with my XP. Once I decided to reformat it to NTFS and tried to do so by plugging into my new windows7 laptop the problems started.
When I connect my wd passport, this massage appears "usb not device recognized". although the cable is working with other devices and the wd passport is also working on other computers (not my...
there is NO problem on you external hard drive..the problem is in your own computer USB port..try to uninstall the driver of your usb port.then try it again.
6helpful
2answers
How to format WD Passport 1TB to FAT32 I have used WD external 500GB passport drive with my samsung 1080p9 dvd player successfully WD 1TB passport drive is not recognised by dvd player
WD Passport Drive running SLOWWWWW on time machine
USB s slow and when you have huge files it tends to bog it down. it is better to have a firewire transfer. another reason could be your computer is doing to much. leave the computer at one task. walk away and let it work. otherwise you will be using memory.
3answers
WD Passport 500GB - My Computer Panel Freezes trying to recogniz
i know this wont help you, but i am having the exact same problem, so at least you not alone. if you have found anything out i would appreciate the feed back and visa versa if i figure it out.
Problem accessing WD Passport Elite drive
The solution to this is associated with the power supplied by your laptop to the drive. It seems the passport drive needs about 1000mA of current which will be supplied by two USB ports on a laptop. It should be fine with a desktop USB port though is what I was told.
2helpful
WD Passport 250GB External cannot be recognized.
Go to BIOS (Press DEL or F2 to enter BIOS). Check if the Power state is in S1. Ensure that USB setting is in Hi-Speed.
Restart the computer and try using the device. this should fix. Let us know the result.
Thanx
4helpful
2answers
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I have the 80GB WD passport and it suddenly stopped working one day.  The unit lights up but nothing else.  Finally I cracked the case open and found, as I suspected, that the drive is simply a SATA laptop drive with a SATA-to-USB conversion card built in.  I suspected that the card was **** so I disconnected it and used a USB hard drive adapter (http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3770&name=USB_Hard_Drive_Adapter) and I can read/write to the drive just fine.  Best part is that the adapter I use has its own power supply so I'm not pulling juice through the USB cable for a SATA drive.
Even though mine "works" again I don't recommend these drives to anyone.  They're just not sturdy enough or well designed.
Top Western Digital Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Paul Bade
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
