Lands Phones Logo
Posted on Apr 19, 2008
Parrot 3100 pairing with blackberry 8310
Hi
I am desperatly trying to pair my parrot 3100 with my blackberry curve 8310 but it can find the device (parrot 3100) with the phone but when the window comes up to type in the pin number it is not open long enough to type in the pin number.
Please can you help
Many thanks
Simon
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 02, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
206
Points
You have too many phones paired in the Parrot. Delete some of the phones from your parrot and you will be fixed. I had same issue
PAIRING PARROT TO BLACKBERRY 9320
To pair your BB to parrot go to connections
check whether the Bluetooth is ONthe search for devicesand when the name of the system comes..pair with the device.
Thank You.
1helpful
Paired backberry 8520 with parrot ck3100 but contacts will not syn with parrot. tried to transfer contacts to parrot but message just says refer to handsfree maunal .have looked into this with no luck...
Hello chicks,
Pairing both devices from the Parrot Product:
Select Setting / Advanced Settings / Pair with phone / Other phones
* From the phone:
* Select MENU / OPTIONS / BLUTOOTH / ADD DEVICE / SEARCH
* The phone will search for available devices
* Select the Parrot Product name from the list, and enter the PIN code '1234'
* The phone will pair with the Parrot Product and auto connect
Sending contacts via Bluetooth For all contacts sending
* From the phone:
* Select MENU / MANAGE CONNECTIONS / BLUETOOTH OPTIONS
* Select the Parrot Product from the list of paired devices and go to OPTIONS / TRANSFER CONTACTS
3helpful
Cannot pair blackberry 8520 with parrot ck3100
I could not pair the Blackberry Curve 8520 with the Parrot CK3100. After looking at the Parrot website, I saw that the Blackberry was actually supported, so it SHOULD work.
Then I found the solution: the Parrot had already too many other phones paired (4 or so), so it could not pair an additional one. After removing the other phones from the Parrot pairing list, the Blackberry paired without a problem. SOLVED!
Davy
My Blackberry 8310 finds the Parrot 3000 (bluetooth) device, but does not ask for the password, and therefor, cannot connect. How do I get these two to mate? (kidding--I mean pair)
The generic PIN (Which is what I'm guessing you need) for most bluetooth devices is either 0000, or 1234. Please try those and see if that solves your problem.
Blackberry 8310 is paired with Parrott 3100 but ot transferring address book
check your setup>>>
screen menu Option> blootooth setup > enable "address book transfer"
Blackberry Curve 8310 won't pair!
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.phpalso gives you step by step instructions on codes, pairing etc
I cannot connect my blackberry 8320 curve to my parrot hands free
then delete some of the paired devices that you may have already on the parrot device.
2helpful
Blackberry 8310 Bluetooth device no services
I just experieiced this for the second time on my 8320 using a plantronics 510 bluetooth. The solution was to take the battery adn SIM card out of the phoine and leave it out for a full minute. It appears that the phone needs to be rebooted once in a while. I suspect Bill Gates designed some of the internal code.
2answers
RIM 8310 Curve to desktop bluetooth "connection" problem
It seems is something related to this:
http://banagale.com/setting-up-bluetooth-sync-in-windows-xp-using-blackberry-desktop-manager-on-a-dell-d630.htm
I did not try yet, check it if you can an post the results of your tests.
- Ivano from Italy -
4helpful
2answers
H500 won't pair with Blackberry Curve
It might already have been figured out but if you hold the answer button on the headset down until the light stays on steady, it is in pairing mode. You can then go to bluetooth setup on the Curve and it will find the headset.
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
