Whirlpool GHW9100L Front Load Washer Logo
Posted on Jul 10, 2010
Whirlpool ghw9100lw frontload washer
Plastic type liner belt located behind rubber gromet on washer basket is desintegrating.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
107
Points
Did you firgure out what to do? i have the same problem but have no idea what to do
Whirlpool duet ghw9100lw lights on, not locked and still won't start
Just above where the washer door strike goes into the latch is a small round piece of plastic that activates a switch in the latch- is that still there? It will push in and come out as it is spring-loaded.
My whirlpool cabrio has water trapped in the wash basket. Is this normal? Keep getting UL code and checked everything else.
I have the same issue. when I remove the wash basket from the tub the plastic parts all seem to have a lot of water trapped inside them. I am looking for a solution and may start my own question. not getting any fault code at all the washer runs as designed. but the dirty water trapped in the plastic top of and bottom of the wash basket is making the clean clothes smell like a dirty dish rag.
My Whirlpool washer leaks when filling. We have located that it leaks from the plastic liner. Therefore leaking water onto floor.
Hi, The plastic liner you are talking about, is it the outer tub? If you could get me a model#, I could look this up for you.
Please let me know if I can help.
Vic
Inner basket scrapes on bottom of liner tub during spinn cycle
It sounds like the basket drive block is worn. If it looks like the basket drive block has slid down the brake & drive tube (I believe you're calling it the spindle), it's definitely worn out. When this part is in place it sits on top of the brake & drive tube and won't allow the basket to go lower. To replace this, remove the cabinet to gain access to the the inner basket which you will have to remove. On the top of the brake & drive tube you will see 2 small tabs. Align these with the cutouts on the basket drive block. Mount the drum back on top, and tighten the spanner nut. Reassemble the cabinet and you should be good to go.
Let me know if you need more assistance.
Leaking around center spindle gasket of outer plastic basket
There was a hole in the plastic liner tub from the inner metal basket rubbing on it during the spin cycle. I got some plastic cement and put it in there and it willl hold for a little while while anyway. Not a very well designed washer when you look into the guts of the monster.
I have the inner basket out of a Whirlpool LSR5132PQ Top Load Washerand I filled it with water to see water dripping out around the rubber gasket? in the center of the outer plastic liner basket. I'm...
wow ok you have there srprnigs to remove on the right side remove the clip spring by removing the 1/4 in nut driver head screw,,and do the same for the lef side,,,noe you have 1 more spring in the rear,,the counter balance spring this has 2 screws remove them,,now on the right side remove your pressure switch hose...go to the bottom of tub and remove your tub to pump hose..ok nw left hold tub up and twist back and forth and pull at the same time...reverse to put together..onthejob
Not spinning properly
You will need to replace the inner basket and front outer tub assembly. Likely, the spider on the inner basket (drum bracket) has broken which is causing it to be loose and rubbing on the inside of the outer tub. This can be verified by checking for excessive play of the inner basket (hold the front of the inner basket and check for play by moving it up and down).
It's not a cheap repair unfortunately. Be sure to always use a small amount (2 tablespoons for a full load) of HE (high efficiency) detergent to prevent future build up which could cause corrosion of the tub spider.
2answers
Washer fills fine but will not spin
the motor coupling is broken. It is a cheap enough part but can be alittle time consuming to replace. it is located directly behind the motor. it is 2 pieces of rubber and i piece of plastic in between the rubber pieces
2answers
Kenmore Elite ET3
The plastic casing (tub shell) around the stainless spin basket should not become worn unless the spin basket is hitting the outer shell. From my past experience, this is usually caused by a cracked or broken spin basket support (spider) arm on the back of the spin basket, or a shot tub bearing (which is also behind the spin basket). The bearing is actually part of the rear tub shell and is molded into the plastic. It cannot be replaced separately and requires the replacmeent of the shell.
If the spin basket supports become broken, the basket becomes off balance and rubs against the outer shell. This results in excessive vibration, which may be the reason why the support shocks were broken. No...this is not normally expected. Unfortnately, this is not a simple or inexpensive repair, either. If you have a service plan, or warranty coverage, I would recommend pursuing that as a repair option. If you wish to repair this yourself, I can post a link for you to follow, but it is expensive. This will usually require the replacement of the following parts:
Spin Basket
Rear Tub Shell (if bearing is bad)
Front Tub Shell (if spin basket caused significant damage)
Support Shocks (I would recommend replacing all 4)
Optional:
Drive Belt Pulley (can become warped or bent)
Drive Belt (if showing signs of wear)
Rubber Door Bellow (if vibration as caused damage to the rubber)
You can go to searspartsdirect.com and type in your model number to get prices for everything if you like. Everything can be found under the "Tub and Basket Parts" heading, with the exception of the rubber door bellow. It can be located under the "Door and Latch Parts" heading.
I know none of this sounds like positive news, but I do hope you find some of this information helpful. Let me know if you need further assistance.
1helpful
Whirlpool Duet Washer Model No. GHW9100LW, Serial No. CSM2608446, Type No. 199-AWM075/GY
not unless you make it yourself ..replacement handle is just like the 1 that broke
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
