I purchased a DRC6355N VCR/DVD Combo Player/Recorder a couple of years ago, and have only used the VCR Player portion, and DVD Player portion about 6 times each. When I put a DVD in to play, the DVD menu screen doesn't appear - I can hear sound, but nothing shows on the TV screen. Nor can I access the DVD menu using the remote. I've tried different DVD's and the same thing happens. I put a VHS into the VCR Player, and it works perfectly, both sound and imaage - so I know something is wrong with the DVD Player portion. What is wrong and how can I fix it?
With most dvd/vcr combo units there is separate wiring. When I use my emerson combo unit I have it wired that I have to be on different inputs on my tv to view a dvd and a vhs. On some units the vcr portion is wired via a regular cable line, while the dvd portion is wired with the yellow, red, and white component cable. Try inserting a dvd and scrolling through your tv inputs until you find the picture or check your wiring to ensure nothing has come loose. If that has no result you could try wiring it differently if possible to eliminate that as a possibility.
