Are you trying to wire a pool pump?
I found manuals at the Haywood site > I saw nothing for K48m2n11b or anything close to that number
http://www.haywardnet.com/inground/products/manuals.cfmBut lets work on the problem and see if I can give you some help:
After opening a few manual and searching for the word 'volt' and 'pump' ... each manual talks about 'pumps' generically, as if the pump is a separate purchase item.
Lower down on the manual page they have a list of pool pumps. A search for the word 'volt' inside the pump manuals says 'match supply voltage to motor nameplate voltage.'
As you know, each electric device has a label showing voltage, wattage, etc. Your pump should show 120Volts or 240V. I didn't see any mention of 3 phase wiring, so I assume your Haywood pump runs on typical residential wiring? And that you are not using 440Volt or 3 phase.
The 120Volt pump will have a black, white and bare ground.
The 240Volt pump will probably have a black, white, red and bare ground
The 240Volt pump could have a black white and bare ground
First the 120V pump:
The 120Volt line from your breaker box will have a black Hot wire, white Neutral wire and bare ground >>> this wire connects color-to-color with pool pump
Next the 240V pump with black, white, red and bare grounda) The 240Volt line from your breaker box can have the same 4 wires, in which case they connect color-to-color
b) The 240Volt line from your breaker box could have a black white and bare ground, in which case the black goes to black, the white goes to red, the bare coppers are connected, the white pump wire is capped off and not used. If pump does not operate with this wiring, another line from the breaker with wires that match pump might be necessary.
The 240V pump with black white and bare grounda) The 240Volt line from breaker can have black, white, red and bare ground, in which case the black goes to black, the red goes to white, bare grounds are connected, the white wire is capped off
b) The 240Volt line from from breaker can have black white and bare ground, and this connects color-to-color to the pump
HOW do you know if line from breaker is 120V or 240V?
If you know which breaker wire is connected to, then it's easy
If you do not know which breaker
-turn off power
-separate wires so they can be tested
-use ordinary tester
-stand on dry boards
-tape tester leads to sticks so hands are away from power
-turn on power
-test each wire to bare copper
-tester lights up on Hot wire
-120V line will have 1 Hot wire
-240V line will have 2 Hot wires
