Drain pump in bottom of machine is probably toast. Check for pump noise during a cycle test. If no noise, check the electrical connector going to the drain pump. If no power is getting through the connector, check the computer. If power is getting through to the drain pump, replace the drain pump.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
For water pump replacement i suggest you to check the help link
provided below.
click the link below :----
Water pump replacing procedure for all vehicles?
http://technoanswers.blogspot.com/2011/11/water-pump-replacing-procedure-for-all.html
HOW TO REPLACE A WATER PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-water-pump.html
How to route Water Pump Belt for 1992 Oldsmobile ?
http://carbeltrouting.blogspot.com/2011/12/how-to-route-water-pump-belt-for-1992.html
How to replace Water Pump on Car ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-water-pump-on-acura-car.html
How to Remove Water Pump?
http://technoanswers.blogspot.com/2011/12/how-to-remove-water-pump-on-toyota.html
Where is Water Pump located ?
http://technoanswers.blogspot.com/2011/12/where-is-water-pump-located-on-toyota.html
This will help. Thanks.
provided below.
provided below.
