Water will not get hot, when i turn the jets on its in SL mode. how di i reset it to run and heat..??
Need to know what buttons your topside control has... depending on the model, some have a mode button which you press and release and then immediately press the temp up or down, to select SL for sleep (no heat), ST for standard (heat as needed) or EC for Economy (only heat during filtration). If the mode button is not present, and you have a single temp button and light button, try pressing and releasing temp and then immediately pressing light button, repeat until choice appears, then wait, it will hold last displayed mode.
SLeep mode. Exiting sleep is unit specific. A simple way out if sleep mode is to power cycle the unit by turning off power at the disconnect, wait a couple minutes and power back on.
If the SLP or SL Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Sleep Heating Mode.
If the SLP or SL Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Sleep Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Hope this helps.
US Parts Center
Here's the answer that all experts missed. Sleep mode is ST. After you hit temp and then the light button a temp is on the display. That is where you want it. Standard mode doesn't activate after you see a letter sequence, only temp will show. Most likely 70 degrees. It took over a day to reach 103 degrees because I used hose water. Btw, a tech charged me $260 a week earlier and told me the board and pump were shot. Everything works fine.
Omg thank you....saved me a phone call and service call
