NorStar M7208 Corded Phone Logo
Posted on Jul 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW TO RETRIEVE VOICE MESSAGES? DOES THE PHONE DISPLAY YOU HAVE A VOICE MESSAGE? IF NOT, THEN WHAT IS THE FEATURE CODE TO ENTER AND OBTAIN MSGS.
george peters
Level 3:
President:
  • NorStar Master 860 Answers
  • Posted on Jul 14, 2010
george  peters
NorStar Master
Level 3:
President:
Answers
860
Questions
0
Helped
609094
Points
3471
The display on a Nortel set will say "message for you" if there's a message in your mailbox. To access your voicemail you can press your open voicemail key if its programmed or press feature 981.If you wish to retrieve your messages remotely, call your office, when the autoattendant answers the call press ** followed by your extension number, your password then # (ex. **2231234#).
1helpful
My Uniden M/N:D1788-2 is not working correctly. It will only ring once before machine picks up & red light continues flashing.
Likely the two ring answer is "toll saver" You'll need to retrieve new messages. Once all new messages have been reviewed, it should return to the programmed number of rings, see "ring time" in the manual.
ALL messages may be deleted as follows;
delete all messages With the phone in standby, press Delete; press Delete again to confirm.
If answering system messages have been retrieved, a continuing flashing indicator could be your voice mail service;
Voice Message Notification • If you subscribe to a voice mail service, your phone can notify you when you have a new message. This feature supports Frequency-Shift Keying (FSK) notification. Contact your voice mail provider for information. • When you have new messages, the display shows a message icon. After you listen to your messages, the message icon turns off. If it doesn't, you can reset it. With the phone in standby, open the menu and select Global Setup; select VMWI Reset, then select Yes
A copy of the manual is available from Uniden;
A copy of your manual can be downloaded free of charge from;
http://www.uniden.info/download/ompdf/D1788om.pdf
How to retrieve messages when not at home? Model 26976GE 1A
REMOTE ACCESS
This section explains the remote access process for use with any touchtone
phone.
1. Dial the phone number for the answering machine.
2. After the answering system answers, press any numbered key on the
touch-tone pad to bypass the outgoing announcement, or wait until
the announcement finishes.
3. Enter the security code after you hear the tone.
4. Follow the voice menu to use the answering machine's remote functions.
The remote feature enables you to perform the following functions:
To Press this button
Review message 1
Play back messages 2
Stop message play back 2
Erase message 0
(during message playback)
Skip message 3
Turn off/on answerer 4
Review voice menu options 7
No valid dialing tones for 15 seconds will hang up the telephone line.
You can get the manual on the link below if you need page 31.
http://www.home-electronics.net/USER-GUIDES/26976_DOM_ES_CL_IB.pdf
Good luck
1helpful
Code to retrieve messages
Here are the instructions you need to follow:
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code" followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press menu again."
Note: The PIN code is set to "80" at the factory.
Remote Operation
When you are away from home, you can operate your answering machine with any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press [0] and enter your PIN code
3) The answering machine announces the current time and the number of messages stored in memory. Then you hear "To play incoming message, press zero two. For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
Command Function Command Function
[0] then [1] Repeat a Message [0] then [6] Answering Machine On
[0] then [2] Play Incoming Messages [0] then [7] Memo Record/Stop*
[0] then [3] Skip a Message [0] then [8] Greeting Message Record/Stop*
[0] then [4] Delete a Message [0] then [9] Answering Machine Off
[0] then [5] Stop Operation [1] then [0] Voice Prompts
* For Memo Record and Greeting Message Record functions, the first time you enter the corresponding command, it
starts the Recording function. If you want to stop the recording, enter the command again.
Note: Once you enter the remote access menu, you must enter a command within 15 seconds, or the
answering machine automatically hangs up and returns to standby.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the
command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering machine automatically returns to standby.
Turn on the Answering Machine Remotely
If you have forgotten to turn on your answering machine, you can turn it on remotely from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press [0] and then enter your PIN code. The answering machine announces the number of messages stored in memory. You hear "To play incoming message, press zero two. For help, press one zero."
4) Press [0] then [6] to turn the answering machine On. You hear the outgoing message and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
4helpful
2answers
How do I retrieve my phone messages when I'm away from home?
To quote from your manual:
http://www.fixya.com/support/p475286-panasonic_kx_tg5632_phone/manual-19838/page-41
Pages 41 - 42
The default remote code is 11 (two ones).
1 Dial your phone number from a touch tone phone.
2 After the greeting message starts (before it ends), enter your remote code.
The unit (then) plays back new messages.
After playing back new messages, the voice guidance starts.
3 Follow the voice guidance as necessary.
4 When finished, hang up.
--Dave
I cannot retrive my voice mail messages from my sciphone i68+
If you have voice mail on a land line as opposed to your cellular phone, you shouldn't have an icon on your cellular phone to retrieve any but the voice mail on your cellular account. If there is a special phone number that you call to retrieve your land line voice mail, then dial it, and enter whatever codes are required to retrieve your land line voice mail.
2answers
Retrieving messages over phone
when your greeting answers, punch in your code, usually a 4 digit code, each manufacturer has their own default code that it comes with.. check the manual or website
1helpful
How to retrieve voice mail from another phone
The factory preset code is "11".
Call your phone from a touch tone phone. Enter your remote code (11, or whatever you set it to) during the greeting message. The number of new messages will be heard, and the new messages will be played.
Norstar M7208 telephone
This could be because you have several mailboxes/extensions set up. We've had the same problem in our office.
As a result, from the phone that reads "Messages for you" you can find out which mailbox is attached to the phone.
1. Press "Feature"
The display will read: "Set: ???"
The numbers shown in place of the question mark will be the numbers to the mailbox attached to the phone.
2. Press "Feature"
Enter 981 for voice mail access
The display will read "Login: "
Enter the numbers from the previous action, and if you don't know the password, attempt to use the default passwords of 0000 or 1234.
This worked at our office. I hope it works for you.
If not? We find the site http://nortstarsupport.com VERY helpful.
If you don't know the password, but have access to the system administrator login, you can reset the password for the set you are trying to retrieve messages.
Good luck
I need to know how to retrieve messages from this phone From another number
1.Call from a touchtone phone.
2.During greeting message, enter your remote code. (Code is "11" by default, or you can set your own beforehand via Menu>Initial setting>Set answering>Remote code>enter your desired 2 digit number)
3. Unit will announce number of new messages, and play them back.
4.After 3 seconds, voice guidance will start; follow as necessary.
Bypass voice prompt by pressing:
1 Repeat message (during playback)
2 Skip message (during playback)
4 Play new messages
5 Play all messages
9 Stop (to resume, enter a command w/in 15 sec, or voice prompt resumes)
0 Turn answering system off
*4 Erase this message (during playback)
*5 Erase all messages
If answering system is off, you can force it back on by calling and letting phone ring 15 times.
Good luck. Hope this helps!
2answers
Voice mail
An alternative to this problem, i've got ...possibly its a COMCAST feature..
Call your own number which will activate the ansering option for COMCAST and then u can read ur messages. This will ge the NEW VOICE MAIL message off ur handset.
In that case i find the answering machine of the phone useless and shouldnt have put money for the same.
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
