A USB drive, also referred to as a flash drive or memory stick, is a small, portable device that plugs into the USB port on your computer. USB drives are commonly used for storage, data backup, and transferring files between devices
https://www.info-bytes.com/
Hello
Another name for your USB stick is Flash drive and it is not difficult to use.
1.The first step is to remove the cover.
2.Locate the USB port on your computer.
3.Insert the connector of the USB drive into the port.
4.Your computer would then prompt you that a new device has been detected at which you can then open the file.
5.Now you can copy and paste the files you want on the drive.
6.After you are done using the USB file,select the icon that says safely remove hardware from the bottom right hand side menu(near the clock display).Then remove the memory stick.
BEST OF LUCK
1. Plug thumb drive or USB into the USB port on the laptop.
2. Go to My computer and see if you see "Removable Disk" if yes then you double click here and you will see the contents of the USB drive.
3. load something from the laptop or PC to the usb just drag document or program from PC drive to usb drive.
4.Go to site called "Ehow" to gain more information.
Note of caution donot just pull USB from the usb port it will erase all the information and the USB drive will then be rendered usless.
5. Remove USB in the proper manner that is goto the "task bar and look for the "safe to remove hardware" icon or go to the "my computer" icon select the "removable disk" icon ( right click) and the select "eject" if the drive is busy or a message comes up that it is then closed all programs associated to it and the "Eject" the drive and remove it from the USB port.
I hope this helps. Have a good day!
