the larger the size of the graphics card the better quality your gaming and entertainment programs will come out. however the graphics card cant always help if your monitor doesn't have a good enough display (480, 720, 1080p)
the motherboard supports only APG graphic crads, as long as you can get AGP your are fine. there are several brands in the market. so i suggest you have a look at the link below.
Its the AGP slot where its in most likely. IF there iw weird stuff on the screen when running 3d apps that can either be a hardware problem or a driver problem. Try updating the drivers first. Most likely the problem is not hardware yet.
You did not mention if the board your running has an integrated video card on it. If it does & you have added the FX 5200 AGP you need to make a change in your bios. Set the bios to see AGP. Re-check the insertion of the AGP card. Remove the video card. Use a strong flash light & look into the AGP slot. Use canned air & blow out the AGP slot. Re-seat the video card evenly into the AGP slot. Try again.
assuming you have set your agp slot in the cmos settings to the primary graphics controller and already had the agp graphics slot driver installed for the motherboard, try using a driver from the nvidia web site if you are having trouble with the driver that came on the cd.
Use the VGA onboard graphics if you have any or fit your old card and click on the link below for XP Drivers
http://www.nvidia.com/object/winxp_2k_93.71.html
If you still have problems then you will have to try an ATI graphics card as it just may not be compatable with your make of motherboard
