The default settings are cashier id: 01 and password: admin
If you changed them, you need to used the changed ones.
If you backed up your database before the re-install, then you should not choose to KEEP EXISTING DATABASE, but rather create a new one. This will let you into the software with the default settings. Then you can restore the backup by using the default password: admin. The database should be named 'cresql' unless you have a different name for it.
However, once restored, you will still need the changed password to open and run the software. If you don't have it, it can only be changed by programming a new one into the database directly with other software. Technically difficult. If you need help, [email protected]
if you want router login password you can try user name as admin and password as admin/password if you want to check the wireless password set up to your computer then
1) press and hole the windows key on keyboard which is next to ctrl key and then press "R"
2)In the box type cmd click on ok
3)you would get a black screen with a blinking cursor where you can type
4)type " ipconfig " hit enter
5) ther would be few numbers typed next to default gate way (eg: 192.168.1.1)
6) type the default gate way number in the adress box of internet explorer
7) it would ask you for user name and password you can try user name as "admin "and password as "admin/password " it would direct you to router page
8)there you can check the wireless password in wireless settings option.
If you have forgotten your Linksys router password, the easiestthing to do is to reset your router to the factory default settings. To restore therouter configuration to factory defaults, hold the reset button on the unit for30 seconds.
Once your router is hard reset, you will need tologin and reconfigure it again.
To reconfigure your Linksys,connect a PC to one of it's Ethernet ports, load a web browser, and go to theURL http://192.168.1.1/. This will take youto a popup box which asks you to enter a username and password to login to yourrouter.
Linksys Default Password
On older Linksys routers, the default username is blank and thedefault password is "admin." On newer Linksys routers, both thedefault username and the default password are set to "admin."
Once you are past the login screen, you are able to reconfigurethe Linksys router.
You want to go to the management tab and change the administrator password tosomething else to keep others from accessing your router.
