Fuji FinePix F10 Digital Camera Logo
Posted on Jul 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fuji F10 is broken-says ''Card full'' lies-Camera now unusable
When I turn myFujiF10 on, a message comes up on the screen saying ''CARD FULL'' and stops you from using the camera. I know That the memory card is empty. It shows on my computer when I have the camera hooked up to my laptop..
How can I fix this?
I can't use the camera!
-Sam
Duane Wong
Level 3:
  • Fuji Master 6,826 Answers
  • Posted on Jul 09, 2010
Duane Wong
Fuji Master
Level 3:
Answers
6826
Questions
6
Helped
2862212
Points
20234
Is there a mode to use the built in memory vs. the memory card? And, you're using up the built in memory and not using the card? That's the way my kodak is, anyway. And, also my Sony Cyber shot.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 07, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
161
Points
The problem is with the photo counter. It has reach its limit.
From the menu, set counting to "renew"
regards
2helpful
Getting message on screen of Read Error while trying to solve the "Memory full" message, any ideas?
Memory full, if it is true, you should backup some pictures and delete them from the card.
Read error, can indicate a corrupted file, dirty contacts on the memory card or a camera malfunction.
for 1 backup all photos and format the card. 2. Clean the contacts on the card and in the camera.
3. Contact a FUJI dealer.
Everything is in the manual (still online) on page 112
On screen IN CARD FULL only took 13 photos no more on card
You can buy larger capacity cards and set your camera for JPEG
not RAW raw takes up alot of room on card
My screen's camera says, "Card is Full."
in camera memory is alredy full but u say only memory card formaat pls look the camera memory and no answer that the card is full
I appear to have lost all my holiday photos due to a crash within the camera when the memory was reading full. Although the camera is not recognising any images on the card It still has a message saying...
you can try to get your images if you use an adapter for the memory card that connect to your computer then there is an application that recover files from a memory card
Hope it will help
Card formated but says it full
Try formatting the card with the cam you want to use. They could be different formats between the two manufacturers or models.Keep one card for one cam and one for the other. This should solve your problem.
Fuji Fine Pix F10 camera says ''card full'' when it is not.
If you plug your camera into your computer again and click Start > My Computer. Your camera should be listed under the devices there.
Double click to view what is inside your camera. You will have to browse to a folder in your camera with a name like DCIM (I can not be exact here since it can vary.)
Select and delete all the images you find on the device.
The problem here is that when you downloaded the photographs from the camera to the computer, you did not check the option to remove the downloaded photographs from the camera, freeing up the space for more new photographs.
4helpful
Camera says Frame no full cant take anymore pictures Help!
Copy your card to hard drive, reformat your memory card, and see what the numbers of pictures it gives you.
If you lower the resolution of the camera, the more pictures you can take.
Im trying to use the memory card but the camera says its full... I deleted everything and used a brand new card but it says the same thing. I even tryed formatting the camera..
Is it telling you the the card specifically is full or just full. Some cameras need to be switched from onboard memory to memory card. Also, if you are using a high capacity memory card make sure your camera can take a hgih memory card. If you put a 2 or 4 gb card in and it says full that means your camera can't use those cards.
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
