Model 786 N Serial no. FEBL 2C008 169U MAG Monitor
Text, desktop scenes and photos have become slightly blurred and I cannot make them sharper with PC or Monitor settings. My screen resolution has always been and still is set at 1024 x 768
Can you offer some kind of fine-tuning help ? I am 86 yrs old and cannot afford to replace this Mag which has given me fantastic service for over 8 or more years
SOURCE: Mag Innovision LT776s Model 780
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
SOURCE: need driver and users manual for mag innovision lt576c monitor
Download updated drivers and manual from Mag website link here: http://www.maginnovision.com/Support/Downloads.aspx where you select product group, type and model.
SOURCE: MAG monitor
The first things that comes to mind is a cable problem. Check to see if there is a bent pin on the graphics cable. Is this a new problem? Did it work before?
SOURCE: i need driver monitor mag innovision for install
Chek Ur OS and download drivers from here :
http://list.driverguide.com/list/company621/
SOURCE: MAG Innovision LT916S monitor problem
Should have clarified I have a Mag lcd LT916s and need a backlight bulb.
Thanks,
Cindy
