It can work, but you can get in trouble, use the original part from link above.
The retailer in first link sells rebuilt part (same circuit), for about $80
this retailer instead sells original part for $150
To work out a solution you need diagrams for both parts , evidently there are differences in the two boards.Check that you connected replacement properly, and that it uses same connection. If you have still problems get the original part.
I have no evidence of compatibility between clock 316101004,and 316101008, standing on your description (providing you connected contacts right) there are evident difference between the two board controls, in the best case, if you have diagrams for both board, it can work adjusting the connections, but you risk to get always trouble. If I was in your shoes I would buy a rebuilt 316101004 for $80. I am posting two links to remanufacturer below
Remanufacture your defective part
control boards - PCBR ...
I am not looking for a part at this time. Rather, need a work-around solution to get the convection oven work utilizing the new part already bought and installed. Why, do you have the Part that is NLA (316101004)?
Thanks
Does anyone know if the convection oven can be made to work with the replacment part that was substituted for the NLA part?
when I push convection bake or convection roast, the oven heats up and the convection indicator shows that the fan is turning, but it doesn't turn at all. I just got had the oven delivered yesterday. Is there anything I can do short of returning it?
