Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Solution for error code c2557 konica minolta bizhub 250 machine
  • Anonymous Mar 12, 2014
    error code c2557
  • Konica Minolta Error Codes and Solutions
    You need to change the drum and the developer, clear the counters from the Service Mode -> Counters -> Special Parts Counter -> and afterwards fun F8 from Service Mode -> Functions ->
  • Konica Minolta Expert
  • 318 Answers
ADTC sensor failure
Posted on Aug 07, 2010
  • bachir abou zeid
    bachir abou zeid May 23, 2015
    Plz check the hopper drive unit and change the solenoid or the sponge located at the end of the solenoid
    This problem make an over toner in the developer unit and the code c-2557
    New Friend:
  • 5 Answers
I went to print on my Konica Minolta C-250 and it didn't power up like normal. So I reset it using the rocker switch by the toners. When it came back up and all the language is in Japanese, it has an error code C-D307 displayed on it in english but that is it. What can I do?
Posted on Nov 27, 2013
    From your description, you have a faulty NVRAM. Try to reset the copier as follow:
    Shut down from the main power switch wait for a few seconds and then start it up while keeping the 'Utility/Counter' button pressed; keep it pressed until the reset button appears on the touch screen, release the 'Utility/Counter' button, touch the reset button nad an ok message should appear below.Restart it normally and it should work. If the error is still there, try to follow the steps provided in the solution found based on your error code. If this does not help, please drop us an email at office@bizhubreset.com ------------------------------------------------------------------- Konica Minolta Error Codes & Solutions -http://www.kmcodes.com Drum, Transfer Belt and Fusing Unit Firmware Reset -http://www.bizhubreset.com Drum and Toner Chip Reset -http://www.chipreset.eu Transfer Belt and Fusing Unit Reset Kit -http://www.resetkit.eu
    New Friend:
  • 32 Answers
Check the drum is good and the developer maybe is missing , the developing unit if not chamge them both and reset program utility counter check details press stop 00 stop 0
Posted on Feb 13, 2016
SOURCE:
How do I solve c2557 error ?
Hi
I found your error code and suggested remedies here:
Error Codes Konica Minolta bizhub 250 Code C2557
This site is very useful as by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a pdf format Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 09, 2015 | Konica Minolta bizhub 250 All-In-One Laser...
Errorc2557
It is my pleasure to guide you.
Konica Minolta 250 Error C2557 is Toner Density sensor problem
Problem: code C2557 - Abnormally low toner density detected Black TCR Sensor
Sounds like something a technician should take care of. Most of the information I could obtain says that the
Solution: Replaced 4038-R729-00 Hopper Drive Assy (C250 part compatible with C252 )
Good luck and please post back that you are successful, giving thumbs up, or if I can be more helpful.
Jun 13, 2011 | Konica Minolta bizhub C250 All-In-One...
Konica bizhub 250 error c255c
there is no c255c code but if it is a c2555 c2556 c2557 or any other c255 code it may need a new image unit. please give more info
Oct 08, 2010 | Konica Minolta Bizhub c203 Copier
We have Konica Minolta Bizhub 250 What does error C2557 mean
Error code c2557 means "Auto Toner Density Control sensor abnormality" (ATDC)
Sep 20, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
My Minolta Bizhub-200 prntr. has a C2557 error code. How do I clear it?
moz-screenshot.pngmoz-screenshot-1.pngC2557 - Abnormally toner detected black tcr sensor.
Reinstall image unit black
Reinstall toner cartridge
Change Image unit
Change toner carridge.
Jan 09, 2010 | Konica Minolta Bizhub-200 Minolta Printer
Bizhub 350 error code c2557, how can i fix this?
This code happens if you replace drum without replacing developer. Both must be replaced at same time.
Sep 30, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Error c2557 konica minolta 250/NEC IT2530
Reset it, start it with the right door open, go to service mode, clear the counters for drum and developer and go to functions menu. Close the right door and start immediately the F8 function. It should work.
Jul 31, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Konica/Minolta biz 350 C2557 after replacing DV unit and drum F8
tha minolta di3510 developer unit looks the same as the unit for the konica minolta bizhub 350 but the toner sensor in the minolta unit uses a different voltage range for the toner sensor and it will throw this code make sure you have the correct unit for this machine also you can try this
go back into tech rep mode and change these settings:
select tech rep choice mode
select printer tab
select atdc sensor gain
set the value to about 165
then back all the way out to the ready screen and power the machine off then back on and replenish toner in the user management screen.
Apr 22, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Our bizhub-250 receives a C2557
hi,
open and close front door cover to reset error.
If it persists you have to execute (TCR Toner SUPPLY)
Tell me if you need to execute it.
Bye.
Mar 05, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
11,556 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
