Please let me know how to update the drivers for belkin 7 port F5U307 in windows 7 64 bit? It is recognised as a ''generic driver''. Seems to function Ok, but when I try to backup data through external usb drive via belkin hub, my laptop suddenly and unexpectedly reboots! Most troubling. When I disconnect the belkin and go direct to laptop's usb port, no issues. Help please.
SOURCE: itunes stops
This could be a lot of things, but I would wager it is the result of network traffic congestion, if this is truly being used for a WiFi network... First thing to troubleshoot this would be to take the WiFI out of the mix and just use a hardwired solution to see if it still hangs.. if so, then the problem may be drivers for your system, and you may need to upgrade them..
May even be software.. might try seeing if any newer versions of your player are available.
SOURCE: my computer does not recognise my Belkin 7 port hub.
sometimes the power it gets from pc fails but if it is powered alone check outlet or strip
If you need more help come back.Post /
thumbs / testimonial are
welcome!
