MGE UPS Pulsar Evolution 2200 UPS System Logo
A
Anonymous Posted on Jul 01, 2010
What can we do if in my mge ups (pulsar mx) is displaying dc bus low shutdown?
Swarnava Palit
Level 2:
New Friend:
  • Expert 114 Answers
  • Posted on Jul 19, 2010
Swarnava Palit
Expert
Level 2:
New Friend:
Answers
114
Questions
0
Helped
63976
Points
187
Prag board(main board ) not working properly . Replace the board to solve the problem.
1 Related Answer
Swarnava Palit
  • 114 Answers
SOURCE: WHAT SHOULD I DO IF IT DISPLAY DC BUS LOW SHUTDOWN
The problem comming from Prag board and zogh board. replace both card to solve the problem.
Pulsar UPS DC bus too high
where did you find this old UPS> ? I'd bet cash it did not just fail 14 years online TODAY.!?
Redux1 this is way too long but there are many sub models of PULSAR and non told yet. by you.
nor if TOWER OR RACK MODEL is your? wow. that. ? not the same batteries at all in both ever.
did not read your manual first.
14 YEARS old it is, and now owned by APC.com (a 2007 event)wiki it.
The HIGH DC means the Charger output is too high
or the 36v 3 battery loop is broken (no load equals charge voltage is too high DC bus)
if you have rack UPS and use 12vdc batteries, in it (not 6vdc as it must) the DC bus will be too high.
UPS is complex and more so not telling full model numbers of it and photo of if.
the LIST OF what can be wrong, (besides bad PCB inside)
wrong batteries, used, or connected wrong.
battery terms rusty. or just loose.
EXB option was enabled before (14 years ago?) and not reconfigured now that it is gone. now.
battery breaker rear tripped. in inside batteries and if EXB option the outside battery breaker tripped. on it.
wire backwards is prevented with connector keys, but if hacked , any thing is possible wrong,.
no photos of yours, the DC bus is 36vdc on the tower. 3x12=36v
AC LINE IN CAN BE SET 100VAC TO 480VAC, (TO COVER WORLD POWER USED)
if not configured day1, correctly there is no hope, only smoke.
what AC voltage is your country, (at home are you) and freqency, 50 or 60HZ, (most are auto set for Hz)
MGE is nOT MEG. at all. sorry but typos like that make help super hard.
just one of many 1500, I can not guess what your REALLY is, Pulsar has many sub models.
https://www.manualslib.com/manual/821986/Mge-Ups-Systems-Pulsar-Extreme-1500.html?page=1#manual
MGE is now owned by APC for 14 years today, UPS company (a top maker)
and this model is not supported now it is too old,,, found in garage sail for $1 USD, I'd pass on that.
and APC does not support this very very old UPS now. they chose not to support it, but gee call them and ask.
Apc.com, click support , and contact them.
next time post photos of front and rear.
and full model number not just "Pulsar 1500," shortened like that. and MGE not MEG.
and what country you live and if at home or using commercial power , 100v or 480vac or what. LINE POWER.?
last , is , if you buy a used UPS outside of your country it will be wrong AC input line voltage. and must be cured first. by strapping or configuration settings,
I have never seen any UPS made that works in all countries, and the few that do many, must be strapped first.
how that is done is covered in every UPS MANUAL made, in the world.
if done wrong this test step, you will get smoke or worse fire. (only fuse can save you from that done wrong)
never bypass fuses OK
and if doing other hacks say so, tell the hacks , like using the wrong batteries.
Ups indicating shutdown due to 016 dc bus low
Could you tell me what kind of UPS (brand/model) you have? DC BUS low is most likely caused due to DC-DC converter error or BUS error. If you can send me the brand and model I will look in to it.
MGE Pulsar 5000 - environment fault
Go to enter bouton in front of the ups and read the fault code if it's a temporary fault when you try to read the ups show that you have to press 3s to reset
How to fully shut down the MGE MX5000 UPS?
1 - Press the "0" button (28) more than 3s. The buzzer beeps once, and the load is no longer protected by the UPS. It is powered via the Normal AC source. If the UPS is set in frequency converter mode, the equipments will not be powered. If the Normal AC source is out of tolerance, the UPS will generate a 10ms output calibrated break. 2 - For a full shutdown of UPS and connected load, the upstream circuit breaker (notincluded) should be set to the "0" position.
DC Bus Low
This could be because of bad batteries or you need to adjust the float voltage. First replace batteries
Please can you tel me whitch Kind of battery, and how many battery there is in this model : MGE PULSAR EXTREME 1500C RACK and MGE PULSAR EXTREME EXB 1500C RACK
Specifications for MGE Pulsar Extreme 1500 C 2U Rack Battery kit
Voltage 12V (Per Cell) Capacity 6Ah (24W) Weight 8Kg Dimensions 151mm x 94mm x 51mm (Per Cell) Lifespan 3 - 5 years Type Sealed Lead acid battery rechargeable highly efficient, leak proof and maintenance free
I think there are four batteries in the pack.
2helpful
My mge 1500 ups is indicating fault behind with an led flashing red and there is no output from the ups with or without ac input
My mge 1500 ups is indicating fault behind with an Problem with the MGE UPS Pulsar Evolution 1500 UPS System my mge 1500 ups is indicating fault behind with an led flashing red and there is no output from the ups with or without ac input
Hot to test the battery of ups pulsor evolution 3000xl and battery chenged ups shutdown requast or no
Buy a CB10 10 ohm ceramic resistor (10%)
Alagator clips on (+) (-) and on the resister. If the battery can not hold the charge after one minute above 12V DC, but drops very quickly that battery is due to be replaced. Very simple test and cost hardly nothing.
Top MGE Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
