Question about Power Acoustik LT-980/2 Car Audio Amplifier
The red light on the amp is staying on and the green light isnt coming on
Its going into protect mode, meaning there is either a short in one of the transistors
or one of the jumper bars is loose, needs to be re-sodered. Easy fix.
Posted on Jan 18, 2011
SOURCE:
When ready to seal red light stays on
Seal 200 lights - Photo.net B&W Photo - Printing & Finishing Forum
photo.net > ... > Prints & Print Presentation
Jul 29, 2004 - 4 posts - ‎3 authors
I'm sure one is a ready light but would really like to know the details. ... I have the Seal110S unit and the red (really orange) light stays on when ...
SmartSeal™ V3800 Series at FoodSaver.com.
www.foodsaver.com/...sealers/smartseal.../vacuum-sealers-help-and-...
TiliaHow does the new FoodSaver® with SmartSeal™ Technology sense the ... My unit isstuck, it will not open, and unit is not allowing me to feed bag into unit to ...
Quickstart Guide for Hospital Staff - Creche Innovations
crecheinnovations.com/new/wp-content/.../Quickstart_Guide_2012.pdf
Seal the blue zipper tightly. Place feeding into inner bag. Seal the ... Ready. When red light is on. • Warming is occurring. When green light is ... light stays on.
What Causes the Brake Warning Light to Come On ...
Jan 05, 2016 | Cars & Trucks
Plasma tv green light flashes 5-6 times then stays green but no picture or sound
Remove one at a time the Y sus and Y buffer cables that go to the power board and see if the set stays on then, you may have a distorted pic, replace the board that makes the set stay on...there are some transistors on the buffer board that give issues a lot and I'd guess that's where your issue is at
Jan 27, 2018 | LG Televison & Video
The Ground wire is hooked up right but the red light wont go off and stay green so the amp will work. It is very frusterating all the cables are the right size its is a 1000 watt amp. I have two 500 watt...
Sounds to me like the amp is going into protection mode. Try placing one sub on the amp with very little gain. One of the biggest reason why this happens is because the subwoofers are wired wrong. What is the brand and model number for your amp?
Apr 14, 2011 | Car Audio & Video
Battery #1 terminal lights red and stays red.
Disconnect the - lead from that battery, Repower the charger. The LED should be green. If it stays RED, charger defective.
Reconnect the - lead to the battery, measure voltage when charger is on. Should be between 11.5 and 13 volts. If OK, replace the battery. If lower than 11.5, check for charger cable connections OR for a connected load ( power drawing ) of more than 10 amps.
Sep 20, 2017 | Guest 2631a 30 Amp Battery Charger
LG rear projection tv. sound but no picture.
Go to a repair centre, some parts must be fixed/replaced.
Jul 22, 2009 | LG RU-52SZ30 52" Rear Projection...
Pyle dryver amp light protection stays on not green light stays red i have tried to disconnect everything and plug it back up but light stays red
check your subs disconnect them the try to power the amp up if it powers up the the subs have died and it could be a problem with that amp i suggest you get a better amp
Jul 09, 2009 | Pyle Dryver PLAD213 Car Audio Amplifier
Protection Light Comes on
your amp isnt getting enough power to it you may need to install a compacitor unit
Mar 23, 2009 | Sony NTX-2136 DHD 2Channel Car Amplifier...
Light stays red
I do belive this amplifer has a red light when it is on... I know my Kenwood does. I suggest checking all your wireing between your amp and your speakers, check the impediance between your positive and negative terminals on your leads to the subs.
Mar 28, 2007 | Kenwood KAC-7252 Car Audio Amplifier
Power Acoustik LT-980/2 Car Audio Amplifier Logo
277 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Dalynn Turner
Marvin
Marvin
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
