Make sure you have the most recent itunes before you do this its pretty lengthy but should hopefully sort your issue!!
Error occurs while syncing music
The error will most commonly occur while syncing music. This issue can be resolved by following these steps:
If
the above steps do not resolve the issue, check the device and the
iTunes library for duplicate voice memos. If you find any duplicate
voice memos, delete the duplicates and then sync.
If those steps do not resolve the issue, then follow these steps:
Test in a new user account
If
the steps above do not resolve the issue, attempt to sync with iTunes
while logged in as a new admin user. Follow these steps to create a new
administrator user:
Windows XP, Windows Vista, and Windows 7
Mac OS X
If the error does not occur in the new user account, other content is causing the error. Proceed to the next section.
If
the error does occur in the new user account, the issue may be caused
by content downloaded to the device, such as podcasts. Removing content
from the device may address the issue.
Error occurs while syncing other content
If
the error occurs while syncing content other than music (applications,
podcasts, and so on), perform the same steps as above, but deselect the
content that stops the sync. Deselect one type of content, then
attempt to sync. Continue until you sync without error. Deselect Apps
last, since restoring your Apps would take longer than restoring other
content.
Find your solution from the list,
Apple Iphone Smartphone
Codes:
Software & Hardware Problems
Find Solutions for other Apple Products:
Apple Iphone 3G
Apple iPod Touch Digital Media Player
Codes:
Find Your Solutions for other Apple Products:
Apple Iphone 3G
SOURCE: Error code #13019 iphone not syncing w/itunes
I googled this question and found out a lot of people are having this problem. Check this thread out for the solution. It worked for me.
http://support.apple.com/kb/TS2830
SOURCE: I keep trying to sync my iphone to itunes, but it
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Can't sync my iPhone, due to error code 13019
This error is usually resolved by updating to the latest version of iTunes. Currently, it is iTunes 10.
If the error still occurs after that, deselect the syncing of voice memos, or better yet, remove the check on the Sync Music checkbox then click Apply and immediately right after the sync is finish, check the Sync Music checkbox again and click Apply.
For more iPhone / iPod touch tips like jailbreaking and unlocking, CLICK HERE or contact me personally at this email:
[email protected] or add me on Skype: ebayseller.ca
