Solve f:23 code error bosch model logixx edition75 was28775
Usually means there is water in the base pan and the flood safety has been activated. If you tip the unit forward a touch you will most likely find that water is expelled from the bottom front. The machine should work but obviously the source of the leak has to be found. Check door gasket for tears etc, water valves and drain hoses.
Hope this helps.
Unfortunately I have encounter to f:23 erorr and the washing machine's door was locked,I opened the small front door and controled but there isn't leaking water?? Is there any suggestion else?I need help!
