Avaya 5400 Series 5410 Phone Logo
A
Anonymous Posted on Jun 18, 2010
Hi I need to re set the number of rings on my Avaya 5410 anwerphone before it answers because it takes ages. How do I do it?
A
Anonymous
You need to do this in the Manager application. Under the telephony tab of the user, you can change the "No Answer" time.
Would like to reduce the number of rings before going to voicemail on our AVAYA phone.
You will need to go into Manager, and adjust teh voicemail timer. By default it is at 15 seconds. Figure 3.5 seconds/ring when figuring out how long you want it to ring before going to vmail.
2answers
Is it possible to get caller ID for an incoming call if I have that number saved as a speed dial? If so, how do I get that. My phone is the Avaya IP Office 5410. Thanks
If the number matches the CID number, you should get the name as well. But here is the hard part.
IF your system requires you to dial an access code (say 9 to get an outside line) you may have that speed dial number saved as:
913125551212
If so, the incoming caller ID would have to match exactly, meaning CID would need to show 913125551212 in order for this to work.
BUT, caller id probably only shows 13125551212, and as such, wont work.
AVAYA 5410- want to turn Caller- id off
Do you have access to Manager? You can tag the incoming call which does not show the caller ID of a call until the call is answered.
2helpful
2answers
How do I set up voicemail on the 5410
Press the voicemail button and follow the prompts. You will need to know what the password is. When prompted for the password, try just pressing #
Need to transfer hunt phone lines to answering service
Make sure that you have allow analog trunk to trunk connect enabled in lines, analog options.
That will take care of your problem unless someone deleted Call forward short code
Trying to change number of rings before voicemail
By default individual coverage is set to 45 seconds. Ask your phone vendor to reduce it.
Plantronic 510s
The Voyager 510 is not a good fit for that phone. I would prefer the cs55 or awh55.
The headset will work with the phone, but will not alert you when there is a call.
Top Avaya Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
