EliteGroup BKi810 Motherboard Logo
Posted on Apr 18, 2008
Usb everytime I inserted usb my pc turn sock-up or idle.
  • Anonymous May 11, 2010
    Is this the USB ports at the front of the computer, or the USB ports in the rear mounted onto the motherboard?
A
Anonymous
The usb ports are mounted on the back of the motherboad.
The ones on the front or side of your tower case are connected to the mother board via cable that plugs into terminals on the motherboad.
letmehelp
A
Anonymous
Check to see that if ur USB has infected with virus or scan your pc. let me know
Hang when usb inserted
look into the usb and make shure the plastic protector is still on the metel tabs..
My Kingston 8GB USB is not working. The device icon shows in my computer but everytime i try to access it, a message pops up indicating "insert disk" or "no disk". Checked the...
It sounds like your USB stick has died on you. Unfortunately USB drives are not very durable and these things happen, I've been through at least a dozen now! Try it in another computer and see if it works there. If it does then try updating the USB drivers on your PC.
What really can be the cause of my pc rebooting the moment i insert my pendrive?
Hello there.
If you are saying that the computer reboots everytime you insert the USB device, most likely the cause of this behavior is due to a virus. A virus that is currently on your pen drive. I would suggest you have it scanned first using an Anti-virus so that your computer will not be infected.
1helpful
2answers
Usb devics not recognized
try it to a known good USB port. if still unsuccessful connect it to another PC that has a known good USB port. if still unable to work. you might have a bad USB stick..
Hope it helps!
PNY 8GB Flash Drive - PC Will not recognize
Have you installed a scanner/another external USB drive since first trying your Flash drive? If so, try unplugging that and re-insert your Flash drive. I had this problem and a friend suggested this and it worked!
1helpful
2answers
Everytime i insert my sd card into my vivicam 5399 it freezes?
tried formating the card ??? plug the vivicam with the sd card into ur pc with the unit turned off when it comes up in "my computer" right click the E: or F: drive and format
Sep 05, 2009 • Cameras
3answers
File system error
you may need to format the device > insert device to your PC > go to my computer and format to FAT instead of FAT 32.
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
