SOURCE: Phone turns off every couple minutes and then turns on by itself.
What I would do is turn it off completelly for a few minutes. take out the battery and let it cool down for a few minutes. If you have a battery that if fully charged put it back in and turn on your phone. if your battery is not totally charged, charge it. A phone whose battery is not fully charged may cause your phone to flip out. sometimes it's also water damage to the phone that causes it to turn off on its own.
Water damage happends from body heat, from taking it to the bathroom when you're in the shower, or from putting it directly in water.
Hope this helps.
SOURCE: my blackberry storm will not charge while it's
what you need to try to do is reinstall the blackberry OS (operating system) on your device.
Assuming you have Verizon
First install Blackberry desktop manager it should be in the CD that came with the phone.
If you can't find it download it <a href="https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=5E695511C1F9656B8E3E63DAB060F469">HERE</a>
then download the OS software for your phone <a href="http://vzw.smithmicro.com/blackberry/download.aspx?ct=personal">HERE</a>
Connect your phone to your computer and start Desktop manager.
click on application loader, on update software click start, click ok on USB pin selection.
when you get to the device backup and restore options, click settings and make sure backup options box is unchecked and device data boxes are both checked, click ok, click next, skip the email signup stuffs,and finish.
After the software is installed the phone should boot back up.
SOURCE: BLACKBERRY BOLD HAS NO POWER,WILL NOT TURN ON
I have the same problem with my Blackberry 8120, died this morning, will not switch on, no red light, no charging light, completely dead... my computer does not recognise the blackberry at all so cant install any new software.. plus I need to recover all the information that is on the handheld... please help if you can....
SOURCE: My new Blackberry Bold will occasionally shut down
same **** - whats going on with our new blackberrys .. is there any solution ?
SOURCE: Blackberry Storm Freezes
I have an 8100 BB Pearl: make sure your Sim card is in perfectly straight. Mine was lobsided a Tiny bit and worked but froze every few minutes or so. I could make calls out though. Now it works fantastic!! I appreciate your web site. Thank you. If I wouldn't have found your site, I wouldn't have figured out my problem.
