Question about Canon PIXMA iP90v Printer
I have a canon pixma ip90v and get troubleshooting messages for missing ink cartridge. Changed the inks, and still nothing prints. What do I need to do?
    Scholar:
  • 117 Answers
This error mostly occurs when the printhead is starting to go bad.
Posted on Jul 06, 2010
SOURCE:
I cant print it says I'm out of black link and I just replaced it and it's flashing E 1 6
From http://www.refreshcartridges.co.uk/igloo/clearing-canon-pixma-error-message-e13-e16/
Locate the STOP/RESET/RESUME button on your printer which is represented by a triangle within a circle on the body of your printer and is usually in red, white or black as pictured below. With the reset button located hold it down for at least five seconds and then release it.
Aug 02, 2015 | Canon PIXMA Office Equipment & Supplies
Canon ip90 has a new print head and ink cartridges but does not print, only goes through the motions. What is the problem?
Remove the cartridges and press the end with the ink sponges onto a paper towel. If you see ink on the towel, insert the cartridges and run the cleaning 3-7 times. This will use up some ink, but is the only way to resolve this issue. If you continue to see improvement in the prints, continue to clean until quality is acceptable.
Great Tech Support by TechbuddiesOnline Call 1 855 517 2433
May 14, 2014 | Canon PIXMA iP90v Printer
Hi, I have a Canon Pixma iP4300 printer and the Yellow ink is not printing. I have changed the cartridge and all other colours are working except Yellow. I would appreciate any solutions you may be able...
I have a Canon Pixma iP4300 printer and the Yellow ink is not printing. I have changed the particular cartridge and all other colours are working except Yellow. I have cleansed the printer several times and tried with new Yellow ink cartridges with new chips, but nothing helps.
What should I do?
Jan 25, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Canon ip90 waste ink absorber warning
Not all the ink that leaves the ink-cartridge gets jetted onto the paper; some of it is "wasted", and goes into the "absorber".
So, the software inside the Canon printer has mathematically predicted, given the number of pages you have printed, and the number of times that you've turned the printer off, that, statistically-speaking, the "waste ink absorber" is almost full.
Take the printer to a qualified printer technician, for replacement of the absorber, and to "reset" the electronics to "zero pages printed".
Oct 04, 2010 | Canon PIXMA iP90v Printer
Canon pixma ip4300 - magenta ink is recognized but not printing
Take the print head out of the machine and sit it in a saucer of very hot ( just off boil) water about 10mm deep for a minute. Take it out and sit in on a pad of paper towel to dry briefly before returning it and the cartridges into the machine. Give it a deep clean and try again. If still no good, the print head has probably had it.
Oct 24, 2017 | Canon PIXMA iP4300 InkJet Photo Printer
HAving trouble printing
Check and make sure you did buy the right one first.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 23, 2009 | Canon PIXMA MX310 All-In-One Printer
Alram light
Did you replace the Black ink cartridge or the Color cartridge, or did you replace both?
Facing the front of the Canon Pixma MX310, did you install the Black ink cartridge to the left side, and the Color cartridge to the right side?
Do Not reverse how the ink cartridges go. Do Not install a Black ink cartridge, in the Color cartridge holder.
If the Alarm light came on, check to see if you have an error message in the LCD. (Not trying to insult your intelligence. The LCD is the little rectangular Liquid Crystal Display on your Pixma MX310 Operation Panel, to the left of the numeric buttons)
Do you have the Pixma MX310 On-screen manual?
Start>Hover on All Programs>Canon>Pixma MX310>On-screen manual
Click on the Troubleshooting heading.
If you have an error message code, click on the heading ->
An Error Message is Displayed on the LCD.
Also suggest you click on the heading -> Problems Sending Faxes.
See if the information provided has a solution to your problem.
Apr 22, 2009 | Canon PIXMA MX310 All-In-One Printer
Pixma Ip90v waste ink tank full
you need to clean the ink tank...it is usually located at the right most part below the printer cartridges.(cartridge ducking station)
check your user manual on how to disassemble your printer or ask someone to do this for you if you are unfamiliar with printer disaabling.
let us know.
Feb 07, 2009 | Canon PIXMA iP90v Printer
Black ink will not print with canon pixma ip90v
Try sending Canon an email through their support website. I had same problem exactly, mine is 1 year old. They sent out a replacement unit for me today. It's worth a try.
Jan 30, 2009 | Canon PIXMA iP90v InkJet Printer
Canon PIXMA  iP90v Printer Logo
147 people viewed this question
Clive
Clive
old marine
old marine
Ekse
