I download from Windows Vista to XP and I was able to find all the Drivers except the Driver Sound for Windows XP.
Download pc wizard to find out what drivers you need search the net for them download install them then store i separate partition of hard drive I have presario c700 and all drivers work. this method should work on any computer converted from vista to xp
Hey People,
I Have the solution for the sound driver of HP Compaq Presario C700 on windows XP.
First Please Download the driver (Conexant HDAudio 221_XP) from the link.
http://upload.gangza.com/view.aspx?ItemID=543d4414-a433-dd11-b0d8-00e08127749e
Now you have to do the following steps:
1- Go to device Manager and open (Sound, video and game controllers).
2- Check if the (Conexant HD-Audio Smart Audio) is recognized?
3- If not recognized go to the next point, if it was then right click and go to properties then under the driver tab click uninstall driver and now scan for the uninstalled hardware and follow the next instructions.
4- Under Device Manager again open (Conexant HD-Audio Smart Audio), now right click and chose update driver.
5- Now Click on (No, not this time) and click Next.
6- Now choose (Install from a list or specific location [Advance]) and click Next.
7- Now choose (Don't search I will choose the driver to install) and click Next.
8- Now Remove the tick (Show Compatable Hardware) and click (Have Disk).
9- Now you should Browse the file you downloaded (Conexant HDAudio 221_XP) and open XP32 and locate the (WiSVHe5.inf) file.
10- Force the installation to complete and then all your problems should be solved.
I did it this way and it's working properly now,
Good luck all, for more information you contact me on my email: [email protected]
Cheers
Please give me Sound Driver of a Compaq Presario C700 Notebook.
Jamshid1290gmail.com
This model of Presario has an audio controller that supports the high definition audio. You need to have Microsoft Universal Audio Architecture (UAA) Bus Driver for High Definition Audio installed on the computer before installing the audio driver.
Here is the link for the Microsoft Universal Audio Architecture driver:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33867.exe
Please do not click on the weblink. Copy and paste the entire web link in a new Internet Explorer Window address bar and click Enter.
After installing the UAA driver, restart the Notebook and then install the Audio driver from the link below .
Conexant CX20549-12 High Definition Audio driver:
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36090.exe
OR
ftp://ftp.hp.com/pub/softpaq/sp35501-36000/sp35940.exe
Audio
Vista has Mirosofts MUAA built in XP does not. You need to install MUAA on XP. Get it Here and install. Your modem will be picked up right away. Now get your XP connexant HD audio drivers. Here. Install.
Wireless
Get the AR5007EG XP 32 driver Here . Click -> start devmgmt.msc . Right click the missing device and select update driver. Point it to your AR5007EG install path. Select specific location then choose then have disk. point it to AR5007EG install path. Select the bottom device that says AR5006.
Vote if this is helpfull
Click on your particular model to be taken to the driver page.
Please vote if you found this information useful.
Thank You
Pls sir,give me the idea to install its drivers
Download drivers
Same problem...
please help me..
Hi Friends,
Compaq Presario 700 PC Notebook's main problem is audio driver for win xp.
For Audio driver software you can visit a link by just Click Here .
For any other problems with this Notebook you can Click Here .
I want compaq es19385 ess sount driver
Plz halp Sound Driver for a Compaq Presario C700 Windows XP
I format my laptop compaq c700..
i dont know where i can download driver..
sound driver and vga compatible...
plz help me TQ
Hey go start button.right click on the mycomputer.then go to manage.then device manager.select sound and audio devices.right click on the audio codecs.u will find update driver.then show thae path where u stored the drivers..then u will get sound...
start>mycomp>manage>devce manager>sound device>audio codecs>update driver.
Http://drp.su/
This sight has all the drivers for every computer and all operating systems
Free with no hassles, no gimmicks, and is awesome
Go to compaq website for support its free and safe.
WOW!! so many go here download this and that and then this again. Why are people making this harder than t is? PC Wizard, Drivermax and various others are complete junk!!! Most of which have strings attached (limited use have to buy to download drivers only scans gives wrong drivers etc.) A program I have come to trust myself has been SlimDrivers from SlimDrivers Free This program to e is gold. sure it has a paid for version that automatically will download and install but the free one works just fine. Yes there is a pop up ad to purchase but this is after you finish the initial installing of a driver. as it let's you know you have it successfully installed. In no way does this ad mean anything such as you have to buy the program for a complete update or to continue to get updates.
However drivers are not always the cause of problems. Sometime another program will reconfigure an original setting without you knowing. Thus we end up thinking there is a problem with the driver. Not at all you may just need to do a simple operation as to restore the driver to default settings Which can be done using device manager.
Your situation sounds like an issue with Microsoft since downgrading to XP. It may not recognize the audio device until all XP updates are installed.
Whether upgrding Windows or downgrading, you should alway make sure that Window updates are completely installed to most recent before installing any program(s) or other updates (Intel Realtek and so on.) doing this will assure everything is properly placed. Unfortunately now XP no longer has new updates but you can still obtain manually all updates through Microsoft for sp1 and once the auto updater is renewed, it will complete the rest. Another thing unfortunate is that tis can take a few hours if not 2-3 days to complete "ALL" XP updates now.
I have formatted my windows xp
i have not working to my sound drover please help me
my laptop model no is c700
Yes I had this problem and sude's link mentioned above worked..posting it again
http://www.mediafire.com/?9duyqzcxwyh
SOURCE: Sound Driver of a Compaq Presario C700 Notebook PC
Here you get Compaq Presario C791TU Notebook PC download
Hi - Make sure you have Service pack 2 installed. If not, download and install. Then follow these directions.
1. Click START
2. Click RUN
3. Type “devmgmt.msc” in the prompt and click “OK”
4. In other devices>> right click Audio Device on ……..
5. Click “update driver”
6. Select “No, not this time” and Click “Next”
7. Select “Install from a list or specific loccation(Advanced)” and Click “Next”
8. Select “Don`t search. I will choose” and Click “Next”
9. From the list sroll down and select “Sound, video and game controller” and Click next
10. Click “Have Disk..”
11. Click “Browse” and choose this folder
12. Select the “/XP32/WiSVHe5′ file and Click “Open”
13. Click “OK”
14. Click “Next”
15. A menu appears saying “Installing …. Do you want to continue?” Click “YES”
16. Click “Continue Anyway”
If this fixes your priblem PLEASE rate this as fixed. If not please don't rate yet. Let me know what happened. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
PRESARIO C752TU COPAQ - I HAVE CHANGED MY OS VISTA TO XP, BUT I DIDNOT GOT THE SOUND DRIVER FOR XP
ya i hv formatted my pc & now i m not getting any sound.the pc shows no sound.
i cant find sound drivers of winxp for compaq presario c700 laptop plz help me
how can you help me.thanks
sound
same probs
Ihave presario C772TU running with winxp2 i find all driver execept sound driver for high defination smart audio 221.
i have purchased presario c700 of compaq ..and i have changed my os xp from vista ...but i can,t find the audio drivers for my notebook...
vista to xp sound driver problems
sound driver for compaq presario c702tu for xp?
sound driver
wireless driver and sound card driver
i think that i have lost my audio driver of presario C700 tell some solution
download Drivers window xp Compaq presario c700
i am not able to find the driver for compaq c 700 laptop can anyone suggest
I have changed my OS from vista to XP and now I lost audio in doing so, kindly advise on this, my existing laptop's model no: C713TU.
Awaiting for your early reply, pls try to get the problem sorted out.
I installed Windows Xp my Compaq presorio C700 my sound not working I need XP sound drivers
ive got a compaq presario 700, but my laptop is playin music but no sound is coming out
same here
when i was playing audio no sound was playing there is no sound
i dont get sound drives for presario c700tu
no sound
Please describe the specifics of your problem below. We'll add
your post as a comment to NOWIS's Sound Driver of a Compaq Presario C700 Notebook PC problem, and notify you when a new solution is offered.
sound driver
I AM NOT FINDING SOUND IN WINXP
c765 laptop sound not working
i reinstalled window xp but notgetting sound 4compaq presarioc700
i unable to find sound driver for my laptop
i dont know how to get audio drivers for compaq presarioC700
I need drivers for audio
I found vista NG for use.
So I install XP instead.
But there's no audio driver available.
audio driver
 i dont have sound driver of window xp i m am call to hp many times but they dont solve my problem
HP should at least say something about Presario F700 sound driver for xp.
It seems this is not a product from HP.
i hate hp because they are not provide proper drivers
no sound drive in my camputer after installing xp in stead of vista
sound is not palying
i used all the drivers of vista on xp except sound driver please how do i do
warshu from Kano Nigeria
i need a sound driver for my compaq presario c702 tu
I changed from Windows Vista to XP, n since thn my sound drivers are not supporting.. pls suggest
same product
same thing ...
compaq presario f700 audio driver for windows xp
i cannot find sound driver for win xp of compaq nootbook c 765 tu
i need audio driver for compaq c700 laptop
Audio driver
i have downloaded realtek but it is not good
have the same problem
send me sound driver for Compaq Presario 700 PC Notebook
we have compaq c700 notebook with xp professional. but not getting the proper sound driver. we try conexant high defination audio driver , that is getting support for volume control. so please suggest correct audio driver.
sound driver
matherchod ye bhosdiwale makelaude compaq wale laptop bech dete hain aur uske driver dete nahi hain. mere paas compaq c700 celeron hai jiske driver inki site pe bhi nahi hain agar kisi ke paas ho to pls post kare.
audio driver
i need sound and vga, wireless driver.?
I have bought 20th june inbilt vista home basic,convert into windos xp all drivers are suported but soud drivers not suported
product no C784tu,
presario C700 please send mail
no driver for xp
need sound driver
s i have the problum with audio driver. i don't know how install the audio driver.
same problem
mother board driver&sound driver
formated xp want a audio driver for compaq presario c700
hello friends, i hv same problem there. if u know any link for download pls help me.
wer to find sound drivers of presario c 700 ..os windows xp
i cant find sound driver for compaq resario c734 pc laptop please send me appropriate link 4 it
sound driver
want the audio driver for this model in xp sp2 prof. OS
DRIVERS
installing sound driver
i installed xp from vista in compaq c700 notebook nd now i m not able to get my sound nd video drivers
there is no sound in windows xp
I have presario c765tu i install windows xp now i am not geting sound driver. Very bad service by compaq
no able to load audio drivers for c700 compaq notebook
sound device,driver install but no sound found that a major problem
sound driver
i have formatted my system pressario c702tu,but there were no sound card installed,hence no sound is coming out.please send me relevant solution
I reinstalled xp over vista and I lost the video and audio in my notebook presario c700
I got same problem. i just downgrade from Vista to XP. My laptop is HP Presario C700 built in Altec Lansing speaker. After everything i got 2 problem. 1st audio sound , 2nd wireless.
Detail driver
Audio driver : connexant High Definition SmartAudio 221
wireless : Atheros AR5007 802.11b/g WiFi adapter
**someone expert please help me.
i installed audio drivers but it doesnt work
I have format my compaq laptop and ihave installed all drivers exept audio drivers pl. solve my problem
i am unable to find the drivers of compaq presario. c 785 tu . please help me to find the solution.
Changed from Window viesta to Win XP, able to find all drivers except the Audio .
I have a compaq c700 series laptop. model number is "C752tu". I have changed my operating system from Vesta to Windows XP professional. I could able to get all the drivers except sound. My sound driver is improper. after installation of the sound driver I found my headphone connector is not functioning properly, I mean after inserting the headphone pins properly, both the speaker are working(laptop speaker and headphone speaker), ideally the later one should work. Please help me in finding a proper driver and installation procedure. right now I can't uninstall whole of my operating system, this is my workstation and I have some system configuration which i don't wan to loose.
awaiting for your response.Â
Thanks
Soumya Ranjan
i want drivers
cannot find sound driver for compaq c765 tu
i have same problem . i formateed my laptop and installed Xp
but i didnt get audio. i didnt find audio driver also
please if any one knows pleas give solutions. my laptop model
presario C772TU
presario C772TU
i have installed xp now cannot install sound card!
no sound driver
im not getting the sound drivers
HI I CANNOT FIND THE AUDIO DRIVERS FOR WINXP FOR COMPAQ PRESARIO C700
sound driver
Compac 752 notebook: changed vista to XP but unable to find sound drivers this is ridiculous---Raghu, vasanth nagar(vijaya)
Compaq Presario 700 PC Notebook AUDIO DRIVER MISSING
Compaq Presario c700 c713tu drivers for xp
audio drivers for compaq presario c700tu notebook
conexant high definition smart audio 221
i need Compaq Presario C700 tage no C762NR ALL DRIVERS FOR WINDOWS XP
i installed one software but not activated the sound
I have the same exact problem... please advice how to fix it :)
i have same problem
Dear Sir,
i have the same problem for the sound driver can't be install my note book,plese help me to install.
thanking you,
best regards,
GANESH.V
m having ma audio driver but it not able to ply speaker's
i am haiving compaq presarrio c700 sound drivver but my notebook is not accepting it, pls help me out
problem with sound driver
i hav downloaded win XP but seem to have problem with sound driver, can ne one help me...
i am unable to install sound drivers
I can't find the compaq presario c 700 audio drivers
Hello! I'm Edem from Mali(W-Africa). I've got to fix my Boss computer, a Presario C700, and had to downgrade to XP. Now I need to reinstall evrything, from sound to network. The worst is i can't even get the keyboard work. Is there anything anyone can do to help me out? Have to send the computer back in this week, if not......No, don't let me think this...
same
c700 xp drivers required if found not installed
same audio problem in xp
iam getting same problem
i have a problem i cant find any driver for my compaq presario c700
note book please get me one or how can i get it help me out
Sound driver for Compaq presarion F700
iam also havin the same problem
audio is not available in my note book
i am unable to play audio in windows xp
Compaq presario C700
i need sound drivers of my compaq presario c700 notebook
cannot play audio windows XP
I am install Win XP SP2 in laptop ..presario C700
The sound card driver not Support my lap . i need C700 laptop's sound driver
sound driver
sane problem
the same for me ...
whats the problem if i attach my headphone it works but the onboard speakers is still audible?
sound driver is not installing in my notebook. and seeing error
while installing audio driver it is saying to reboot again to complete my installation
i cant hear any sound
sir i'm not able to find audio driver for my presario C700...my OS is win xp
sir i have audio drivers,but the drivers r not instaled, now what can i do?
i loaded windows xp service pack2 in compaq presarioC700 BUT DOES NOT FIND SOUND DRIVER
Yes I have exactly the same problem. I am trying to find the sound driver for the compaq as the original motherboard driver was not included with the computer.
I want to download sound driver
Conexant High Definition SmartAudio 221
i am unable to off the laptop volume when i am using head phones
compaq presario c700 notebook pc unable to find audio drivers for xp
sound driver does not install
i have installed xp again because of some problem, but now my audio driver is not working. i tried to install so many softwares but non of these work. i have a compaq presario f700.
help me
i have problem with audio driver in my laptop presario c700 i tried loading drivers provided but still unsuccessful please help me in solving the problem
mute does not work,cannot turn off notebook speaker when using headset.my notebook is a presario c700
in this presario laptop microphone is not working at all need drivers while buying they didnt give drivers cd if i download from netion it wont be correct na pls give somother solut
whats the problem if i attach my headphone it works but the onboard speakers is still audible? the model that i'm using is C795TU
i reinstalled windows xp service pack 2. after installation i am unable to hear sound from my note book pc. windows shows "no audio device ".
i need sound driver for my laptop(compaq pesario c722tu). plz help me to fix this problem. i have windows xp operating system
SOUND DRIVER UNAVAILABLE
I am also having compac presario 700 pc note book. Â My audio drivers are not working properly. Â I am want to down load the drivers & install the same.
do help
I have Compaq Presario C797 VU and unable to install the audio driver on XP
sound
audio problem compaq presario c713tu so help me
We have to find the driver and reistall it.
i am not getting the audio drivers for c765tu for windows xp can u plz get me them or send them.
i want to download compack presario c700 sound drivers free
I am getting Below message when I try to install the sound driver for Compaq C716TU model.
Device Installation failed::Could not find the MEDIA device to this driver.
i need sound driver for presario c700
i need sound drivers for presario c700
I NEED COMPAQ C700 (C784TU) SOUND AND ALL DRIVERS IN XP
i lost my mother board driver
i have same problem for finding drivers of my NB
yes i have same problem
i want to download sound driver
i need audio drivers for compaq c700
my audio drive is not working how to down load the software
my laptops sound or volume is missing
PCI Device drivers are not installed in my Notebook.
I could not find in the intel web site.
i meet the same problem
Yes I Have the same problem
DRIVER
i have this same freaking problem i had a couple of good sites that i got the graphics one from and wireless internet one from though :)
ill be back to upload the site
i mam not getting any sound from laptopo
i am also having the same problem my os is windows xp servies pack 2
Hi
I have a PresarioC700 compaq it works with Vista.Unfortunately when I want to install XP it says disc not known.I can I install the XP sp2 or sp3 along with Vista.adivse me.
i dont have cd drives for my labtop to install sound
i have installed some drivers but it still shows me i should install a realtek audio drivers
my laptop don't have sound after reinstall new windows xp. how can i download sound driver for this laptop?
no sound
i have no driver for high definition audio
my speakers of lap top are not working.when i checked i got that the conexant hd audio smartaudio 221 is not installed
xp sound driver for compaq presario c700
may get soundcard driver compaq presario c700?
i have change fm window vista to window xp. sound cannot hear
This problem is same my problem.. What can i do to settle this problem???
hi dear ,
i have same problem . i have (c784 tu) model and os is window xp .
i can use that os after 6 month but than uadio driver is not properly work pl,z help me dear
pl'z tell me i can wait your ans
bye
i hv degrade my pc 4m vista to xp, have got all the drivers except sound driver
Microsoft Universal Audio Architecture (UAA) Bus Driver for High Definition Audio .... Device Installation failed::Could not find the MEDIA device to this driver
want sound drivers for compaq presario C700
no sound.
I have Presario c 700 (C 702 tu on bill) I formatted the system and sound is not there and message of PCI device is not installed come on desktop.
Please rectify my problem and provide me the suitable driver.
Thanks
Anil Kumar Arya
DLF-2, Gurgaon
Mobile no. 9810997005
i can't be install sound driver of compac laptop
c700
No sound in my notebook
i just downgraded xp from vista but i am unable to find audio driver. where i will get a audio driver downloaded ?
i need sound drivers for XP, becouse i don't like Vista
i format my laptop and than the sound is lost.i m not able to hear the sound. its campack c700.pls post me the solve of the problem. [email protected]
cannot find media
need sound drivers
sound driver is not working properly
i have compaq c700 752tu laptop
vista was initally installed
i want to install xp but i didn`t get the sound driver
plz help me
sound cannot work
i format my laptop compaq c700..
plz help me TQ
I have formatted my window XP.
I have not my sound driver.
plz help me
USEFUL TIPS FOR YOUR LAPTOP
mouse drivers
1-800-532-4187 danger do not call them.
