Kenwood KDC-MP235 CD Player Logo
Posted on Jul 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My car stereo flashes the word "PROTECT"
My daughter had the car and was listening to a CD. It stopped playing and the word "PROTECT" flashed onto the display and now it won't do anything else.
Level 3:
  • Kenwood Master 17,130 Answers
  • Posted on Jul 06, 2010
Kenwood Master
Level 3:
Answers
17130
Questions
0
Helped
3635047
Points
52372
If this happened while playing music at a little higher volume, you must check the speakers for short in coils. disconnect the speakers to see if the protect condition changes, if so check the speakers and wiring. If not then you must have blown up the output IC or a power shorting within the set. You will have to remove the pcb disconnect the power to the output IC to confirm the fault. Helpful I hope. Good day
Trying to play flash drive in USB port on stereo
Make sure that the music files are indeed mp3 format. An iPod will play several different formats but most av head units only play mp3. A lot of the songs that are downloaded from iTunes are actually mp4
How to fix my stereo thats saying protect
Disconnect the loudspeakers, if this solves the problem, one or both loudspeaker is in short circuit, if not the amp is broken and you need to have it serviced. If it is happening only when listening at high volume, turn the volume down ;-)
4helpful
3answers
JVC KD-R610 is stuck in Protect mode
Try disconnecting your battery, reconnecting it, and resetting your stereo. If that doesn't work, the constant power (yellow wire) or ignition wire (red wire) may have come in contact with ground or isn't properly connected. Make sure everything is connected properly and try resetting your stereo. If it is still flashing "protect", the unit needs servicing Contact JVC Customer Care Center at: 800-252-5722.
51helpful
3answers
Kenwood car stereo cd player reads protect mode how do i fix this
i have a kenwood kdc-241 car stereo and it has gone onto protect mode i have done everything it says in the manual and even taken it out of the car just in case it was damp i have tried putting it back in but still is in protect mode can anyone help me please
Kenwood KDC-MP235 CD player flashes Protect
check for shorts in your speaker wiring..
6helpful
2answers
KDC-MP443U - flashes protect
I had the same Prob on my KDC 237. I hit the small reset Button on the front and it fixed it. Hope this helps.
62helpful
9answers
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
3answers
CAR STEREO
El amplificador de audio se te quemo necesitas llevarlo a un taller para que te lo reparen.
Can't do anything - LCD screen says "PROTECT"
It may be that there is a problem with a fuse inside the stereo. It may say protect because the fuse has broken a connection that allows it to turn on. If the protect goe sup it is trying to help save the stereo from cooking its self, and give you a chance to get it fixed. If that is not the problem then it may be easier to just buy a new one, because a fix may be expensive if you don't have any warranties.
2answers
Amp goes to protect mode only on cd play
Do you get adequate bass on the radio, or is it a bit quiet on the low-end?
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
