This could possibly be, you have some water from condensation buildup inside the tank, liquid does not compress. Before this next step make sure the tank is to 0 psi! Now, there should be a relief valve Wingnut on the bottom. Loosen the wing nut and drain as needed. Then retighten the wingnut (Do not overtighten). Plug the compressor in and try it. My second suggestion is, the psi adjustment pressure knob could be faulty replace as needed!
The problem with compressors not building pressure is usually a bad pressure switch or bad regulator. Does the motor shut off at 20psi or does it continue running and not build pressure? If the motor continues to run with no increase in pressure, the you should go over the machine looking for air leaks from your regulator back all the way to the motor. Any air leak while the compressor is running can cause the pressure to "peak" way before the intended shutoff that it is regulated to.
Bad check valve. But I would check the regulator, by turning it down to about 10 PSI and running it and see if it builds again, if that works then it is the check valve. But from what you are saying I would replace the check valve anyways.
Is you air regulator working? I suspect your reed valves in the head need replacing as they may not be holding pressure over the 45psi that you mentioned, and are allowing the air pressure to defeat them which allows the psi over 45 psi to bleed back into the air compressor cylinder.
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
My air compressor builds up to 40 psi and just keeps running, i have a craftsman 5 GAL, 1HP, 125 PSI and pressure goes up to 40 psi and dose not go any higher and on the other hand engine keeps running and dose not stop. Please advise?
Thanks.
Kia
