I have a Numark Stealth, DJ IO and Traktor Pro, I want to configure the Traktor Pro so that one can listen to main track on main speakers whilst I cue new track in headphones separately... how do I do this?
if your desktop has two audio outputs (one for headphones and the other one to connect the speakers - both green), then you dont need dj io (or a second sound crad on the side), just go to config and chose the sound card settings to double inputs and in outputs chose both speakers and headphones' depending on what software you are using. questions [email protected]
Are you using a Mixer as a pre-amp for this set-up? For example, I have a Numark CM200 where I have all of the inputs and outputs I need to run. DJ IO is connected to Chanel 1 and Chanel 2 Lines in my mixer. The DJ IO is conected to my computer by USB cable. In Traktor souncard settings chanel 1 is set to (3&4) Chanel 2 (2&1) also, devise set up is Numark DJ IO and in External mode. Of course the mixer is conected to my amp and speakers conected to the amp as well.
the outputs in Traktor should be set up like this; Chanel 1 (3&4) Chanel 2 (2&1) this set up will give you a stereo sound coming out of Traktor using Numark DJ IO. Make sure the output is set up External and the Audio Devise is Numark DJ IO.
get the lastest download from www.numark.com and then go to your startup menu and go to numark folder and change your audio latency setup to the next level and repeat it unitl works
