Replacing a rear axle on schwinn bike. not a free wheel. need diagram of how the parts go back together. son being helpful took it apart before i got home
That's great but I wrote to you about a Magna women's 18 speed Mtn.bike....2 wheels, not 3...so, unless their parts are inter-changeable your information won't help me much!That's great but I wrote to you about a Magna women's 18 speed Mtn.bike....2 wheels, not 3...so, unless their parts are inter-changeable your information won't help me much!
You can't post conmments that contain an email address.
The Schwinn Meridian Trikes use a different type of axle than others such as Sun Bicycle Trikes. The center of Schwinn & Sun Trikes are the same and measured diameter at 17mm, but differ on the threaded ends... Sun Trikes continue with 17mm to the axle ends, but Schwinn Trikes taper down to 12.5mm axle ends to fit their custom size wheels. This Schwinn tapered reduction in axle diameter may be part of the reason why Schwinn axles seem to bend or break more easily.
It seems that Schwinn requested these custom parts size to lock consumers into having to purchase solely high-priced Schwinn wheel/axle parts.
As of 2022, buying replacement Schwinn Wheel/Axle replacement parts is a real pain because Schwinn will not sell direct to consumers, will not disclose Schwinn part numbers, and Schwinn Customer Service tries to redirect public parts inquiries to "authorized dealers".
The problem is most local bike stores no longer carry Schwinn bikes or parts and the retailer "big-box" stores such as Walmart, Target, or Dick's Sporting Goods will only sell Schwinn parts for bikes they stock or have sold to you at that store.
After complaining, to Schwinn Customer Service several times, they finally allowed me to order direct from Schwinn.
It could be one of many things,The first Thing I would do is check whereabouts the noise is actually coming from,ie lifting the back of the bike up with a help of a friend and spinning the wheels one at a time and after both wheels being spun rotate the pedals and see if its coming from the gear cog at the rear,Whatever is the problem the part needs to be cleaned out and a new part put back on.It may be just a cracked ball race in one of the wheel spindles.
Why not call a Schwinn dealer and ask if they can order it for you? You do realize that you void any warranty by altering you bike, don't you? But, if you don't care, look on the www.schwinn.com website and find a Schwinn dealer near you.
The set screws in the center of the axle are there to keep the axle centered in the frame. Only the right wheel is powered which also means only the right wheel brakes when operating the rear brake. This is because the rear wheels must be able to spin independently when turning because the outside wheel will move faster. Unfortunately no one builds differentials at this price.
If you have wheel wobble you need to determine if the axle is bent or the wheel is not true. Prop up the rear of the bike on a stand and remove the problematic wheel. Manually pedal the bike and check the axle as it spins. If the axle is wobbling then it is bent and will need to be replaced. If it spins true then the wheel is the culprit.
The axle is relatively inexpensive and can be ordered through a Schwinn dealer. Any bike shop should be able to true a wheel for around $15-$20.
you need a new axle kit, and a cog removal tool. They used to be a Huret dearailleur if I remember right. I know a varsity never had Shimano. I think you may be better off buying a new rear wheel (it is usually less money than having to rebuild the axle) and let the bike shop do the change over, it is well worth it. You wont have to deal with the brakes,check the cones etc. Why did you have the Meridian adult trike on, and you have an old 10 speed Varsity? Kind of confusing.
