While doing hp printer driver installation in my acer 5520 notebook just after completion the battery was totally down and the computer went down because of low battery. But after plugging in the supply the system is unable to start microsoft windows (vista) . Tried everything to recover but Im unable to start the windows. Any suggestions?
Try to boot in safemode and remove the printer and restart the computer. Guide how to use safe mode.
Microsoft Windows Vista users
Tip: If you are running Safe Mode because you cannot get
into Windows you may want to first try loading the last known good
configuration. Additional information about this mode can be found
on document CH000626.
To get into the Windows Vista Safe mode, as the computer is
booting press and hold your "F8 Key" which should bring
up the "Windows Advanced Options Menu" as shown below.
Use your
arrow
keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if
you press and hold a key as the computer is booting you will get a
stuck key message. If this occurs,
instead of pressing and holding the "F8 key", tap the
"F8 key" continuously until you get the startup menu.
If you still have the recovery discs available then press F11 or F12 depending on which one is the boot menu and boot from the CD and reinstall Vista from it onth the hard drive.
