Televison & Video Logo
A
Anonymous Posted on Jun 27, 2010
I want to program my dish network remote to my tv not my box
Anonymous
Level 1:
Scholar:
  • Contributor 37 Answers
  • Posted on Jul 06, 2010
Anonymous
Contributor
Level 1:
Scholar:
Answers
37
Questions
0
Helped
27499
Points
92
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the TV Mode button on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
4 Related Answers
Anonymous
  • 111 Answers
  • Posted on Nov 16, 2007
SOURCE: Dish Remote
your dish network remote does not have codes for an olevia tv, the best you can do is use the powerscan mode. here are the steps.
1)Turn ON the electronic device you want to program the remote to control.
2)Press the Mode button on the remote until the appropriate mode light is flashing.
3)Press the Address button. The mode light will start flashing slowly.
4)Press the Power button. The mode light will stop flashing and stay lit.
5)Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
6)When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
7)Press the Address button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
8)Turn the device back ON by pressing the Power button.
9)Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
10)If the other buttons work, follow the current settings procedure below to determine the current remote settings.
11)If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
12)The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
current settings:
1)Press the Mode button on the remote until the appropriate mode light is flashing.
2)Rapidly press the Address button twice.
For the SAT mode, the mode light will flash the number of time that matches the receiver address.
3)For the TV, VCR, and AUX modes, the mode light will flash the number of times to indicate each digit of the current code. There will be a pause between the flash sequences for the digits. A quick flash indicates zero.
4)Write all of the codes you programmed on to the sticker that came with your satellite receiver and apply the sticker to the inside of the remote battery cover.
hope this helps,
trin
Anonymous
  • 64 Answers
  • Posted on Nov 25, 2008
SOURCE: dish network remote with a element tv
Since you dont have a popular brand set you should try using the scan method. Here is a link with a video to help program your dishnetwork remote to work with your set. http://www.disheez.com/videos/dish-network-video/programming-dish-network-remote/
Anonymous
  • 247 Answers
  • Posted on Dec 18, 2008
SOURCE: programming a hitachi remote to a dish network box
i would try to reprogrsam the remote first. do yuo have the owners manual to do this?
Anonymous
  • 563 Answers
  • Posted on May 20, 2009
SOURCE: can I program my dish network remote for a rca
Try the RCA codes listed in the code book that came with your Dish remote. You will want to use the "AUX" button at the top of the dish remote. You will likely NOT get full functionality if it works at all, however, there is a chance you'll be able to change the channels and power the converter box on and off.
If the codes you have are segregated into categories of different devices, i.e. TVs, DVD players, etc. You probably will not be successful.
Also, there should be instructions in the remote manual that will tell you how to search all codes that are stored in the Dish remote.
While this may not solve your problem, I hope I've given you helpful information that will allow you to make an informed decision as to where to go from here.
Let me know if I can be of further assistance.
Codes for innovage universal remote to program it with my dish network box
Hi Gw, my name is Mike Houston a Social Media Representative at DISH. I understand you want to program your innvoage remote to our DISH receiver. When we send out our DISH receivers we will include our own DISH universal remotes that can control many different components like; HDTV, surround sound receivers and sound bars. We do not have the codes for other universal remotes to work with our system. I will provide you a link explaining in more detail on programming your remote: http://www.ehow.com/way_5501311_innovage-jumbo-universal-remote-instructions.html
3answers
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
2helpful
2answers
Lost my Dish network remote for the upstairs tv (LG) - which has NO box. Is there anyway to program my TV remote, so I can access the TV staions - turn on the network basically???????
No,the Dish Network satalite box signals require it own remote for it INFER RED INPUT and INFER RED OUTPUT signals.Call Dish Network customer service ask for a another original Dish Network remote.U pay $5 or $6 dollars a month for the satalite box as rental.They should wave the fee or charge u very little for a another remote.
Need codes for one for all remote to reprogram dish network
you will need your Dish network remote to program your dish network box. This universal will not work. but if you need the full codes for this remote to program to your tv then go download the full manual with codes here.
I need the code for tv rsa
The codes and instructions are different for each of the Dish Network boxes. In order for us to give you a direct and comprehensive instructions, we would need to know the model number of your Dish Box as well as the device (TV) you want to program.
If you prefer to look this information up, you can visit the Dish Network Remote Control instructions posted on their site: http://www.dishnetwork.com/SupportSection/remote-setup
Please let me know if I can further assist you.
Regards,
KYTechnology
1helpful
Programme remote to work with sony tv
To program your DISH Network remote to your Sony TV you will simply- press and hold the TV Mode button until all the other mode button back lights illuminate, then release.
-Now while the TV mode button is blinking please enter in the remote code 500 which is the remote code for your Sony TV after entering 500 then press the pound (#) key.
-After pressing the # key on the DISH Network remote, the TV mode button should blink 3 times and then turn off completely. This will mean the programming of the DISH remote to your TV has been completed successfully. While still in TV mode try any of the functions on the remote, such as turning the volume up or down on your TV or attempting to press the power button.
-The DISH Network remote should now be programmed to control your TV.
-If the remote code 500 doesn't program the DISH Network remote successfully you can also try each of the following using the same procedures, 000, 590, 640, 502, 002, or 567.
I hope this resolved the issue for you! Please feel free to contact us if you need any additional assistance.
-Kirstie DISH Network
Have to manually turn on tv when turning on digital converter box
astoner3,
Our dish remotes are compatible with most TV manufacturers. On some older TV, we may not have codes that allow for full functionality for the DISH remote. I have provided the most common codes to work with the Sharp TV. The codes are: 628, 605, 740, 591, and 606. I have also provided instructions on programming the remote to the TV.
Remotes: Basic (Television Only)
  1. Turn the Television On
  2. Press and Hold the TV Power button for three seconds until the LED flashes
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK. Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Ray Calo
DISH Network
4helpful
Dish network remote with a element tv
Universal remote
only a uhf remote will work from that location, you will probably need to get a dish network 6.0 or 6.3 remote
Programing a remote
i would suggest programming your dish remote to your tv,
Top Orion Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
