Hitachi CP-X300 LCD Projector Logo
Posted on Jul 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to change Hitachi Projection Logo on Hitachi models X260,300,440.445 and 880 to our own logo. how do we do this please?
Nancy
Level 2:
New Friend:
  • Expert 45 Answers
  • Posted on Jul 05, 2010
Nancy
Expert
Level 2:
New Friend:
Answers
45
Questions
Helped
26488
Points
122
I have a clarionfx508au Cani change the logo
Add your logo to customize your survey. When you add a logo, it will appear at the top of every page in the survey.
Upload Requirements
  • Format: JPG, PNG, or GIF
  • File Size: 1MB or less
Adding a Logo
To add a logo:
  1. Click the Design Survey tab.
  2. At the top of the survey, click + Logo.
  3. Upload a logo from your computer.
  4. Once you successfully upload your image, configure the logo settings in the left sidebar:
    • Logo Size - Choose to display your logo at its Actual Size, Small (100px), Medium (200px), Large (300px).
    • Position - Choose to display your logo Above Title, Below Title, or Left of Title.
Your changes will save automatically.
Changing or Editing a Logo
You can change your survey's logo at any time, or edit the size and position of the existing logo.
To change or edit a logo:
  2. In the left sidebar, click OPTIONS.
  3. Click Logo.
    • To change the logo, click Replace.
    • To edit the existing logo's size or position, use the Logo Size and Position fields.
To center your logo:
  1. Go to the Design Survey tab.
  2. Click on the survey title in the design.
  3. Find the Alignment field and select Center Aligned. The alignment of the logo always matches that of the survey title.
Deleting a Logo
To delete a logo:
  3. Click Logo.
  4. Click Remove.
The logo will be removed from the survey.
Mitsubishi logo scrolling all over 73" Tv screen?
what is model number of your set and is it like a screen saver moving?
I am not getting any signal between my laptop and the projector. i am connecting with a vga cable
Hi i'm Allan!
There is some keys that you may have to press on the Laptop for it to connect to your projection, usally its FN key plus "F#" key that has the monitor logo. Different on every laptop though. What's the make and model of your laptop?
Keep me posted. Thanks!
Sony Lens Cap for A100
The Lens cap model of the Camera depends on the model of Lens which you're using with the Camera. The model # of the Lens Cap for the Camera body and the lens differs. Few models and the details are given below:
55mm Front Lens Cap - G Series logo
Model Number: ALC-F55G
72mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F72Z
77mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F77Z
77mm Front Lens Cap - G Series logo
Model Number: ALC-F77G
α Rear Lens Cap
Model Number: ALC-R55
62mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F62Z
49mm Front Lens Cap - Sony α logo
Model Number: ALC-F49A
62mm Front Lens Cap - Sony α logo
Model Number: ALC-F62A
62mm Front Lens Cap - G Series logo
Model Number: ALC-F62G
67mm Front Lens Cap - Sony α logo
Model Number: ALC-F67A
55mm Front Lens Cap - Sony α logo
Model Number: ALC-F55A
72mm Front Lens Cap - Sony α logo
Model Number: ALC-F72A
77mm Front Lens Cap - Sony α logo
Model Number: ALC-F77A
Please enter the SonyStyle webpage and check for the compatible ones for the Lens which you're using.
Thanks for using Fixya.
We wish you a happy holiday season..
2helpful
2answers
Remove logo from sony
in the message settings you can find the operator logo you can turn off it
Change the logo message on a sharp xe-a21s
i need to program the crv on the machine. can some body help me?
THE LOGOS FROM DISH NETWORK ARE A FADED GHOST IN TV EVEN WHEN DISH NETWORK IS OFF
Hi my nameis Mike Houston of DISH Network and I see you're having a faint DISH logo onyour TV screen even when the TV is off. If you will please unplug the receiverfor 10 seconds and unplug the TV for 60 seconds and while unplugged check tosee if the DISH logo can still be seen, if you still see the logo after boththe TV and receiver are unplugged there is an issue with the Television tube.
Dell Dimension 5000
please reset the bios..on dell logo..press f2..press num lock, caps lock ,scroll lock so that all three are on. press alt e
press alt f
select the option that says
save changes and exit
your hdd should get detected.
please post back if it does not work so that i can check out fir further options
BIOS
just remove cmos and reset it by jumper settings
Top Hitachi Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
old marine
old marine
ZJ Limited
ZJ Limited
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
