How do i copy contacts from phone to sim?
Previously check the phonebook memory status of ur sim it might be full some old simcard provides very less contact storage varies from 10 - 250 for newer sims
if sim is full then u can not copy contacts in it
or if it is not though then u can check ur sim by copying contact from inserting it in another phone if it works then ur mobile is faulty
Or
check it vice versa
if this is helpful let me know regards
SOURCE: copying contacts to SIM card
To copy numbers from the phone to the SIM.
Select 'Menu'
Select 'Phonebook'
Select 'Contacts list'
Highlight the contact you wish to copy onto the SIM
Select 'Options'
Select 'View'
Highlight the number (not name)
Select 'Options'
Select 'Copy'
Select 'SIM'
Select 'Save'
display_flip('id3944', 'divId3944');
SOURCE: Cant copy phonebook contacts from sim card to phone memory?
Go this way
Menu > Phonebook > Options
Scroll down to Move and select.
Select Multiple from the pop out.
In the list just check All or whatever contacts you want.
HTH
SOURCE: copy contacts from sim to memory card on samsung
Go to contacts. Hit the contact you want to copy to sim. At the bottom right it says MORE. Touch that and the option to copy to sim is there.
SOURCE: COPY PHONE CONTACTS TO SIM ON THE SAMSUNG G600
Press the following buttons:
Menu (left 'hot key'), 2, 7, 2, 2
That'll do it! :)
-ComradeHaz
SOURCE: I have a Nokia E71 and using SIM from my old
open "address book", then press "option"scroll down to "SIM contacts" and press the right-navigation key and select "SIM Directory"
It will display contacts on your SIM card. To copy contacts from SIM to phone memory. Select "Options" then scroll down to "Mark/Unmark" press right-navigation key and select "Mark All" then select "Options" again and then select "Copy to Contacts"
That will copy your contacts from SIM to Phone directory.
