Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
Posted on Jul 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What channel do i use to use the DVI entry? - Hitachi 51F500 51" Rear Projection HDTV-Ready Television
Anonymous
Level 2:
Scholar:
New Friend:
  • Expert 50 Answers
  • Posted on Jul 05, 2010
Anonymous
Expert
Level 2:
Scholar:
New Friend:
Answers
50
Questions
0
Helped
16759
Points
127
It's actually an input you will use, & not a channel. Usually most tvs have about 3 or 4 or even more separate inputs. It should be labeled next to the DVI port which input it is. To switch to it on the TV use the button on the remote labeled "inputs" or "TV/Video" and cycle through til you get to the right one. Sometimes that button is right on the TV as well.
Azrael SRL
Level 3:
  • Hitachi Master 11,800 Answers
Azrael SRL
Hitachi Master
Level 3:
Answers
11800
Questions
0
Helped
2566911
Points
35672
None, channels are only on the tv source entry. The DVI is just another AV entry, to use it you just select it from the other AV sources.
What is DVI?
VGA cables are the standard way of connecting analog monitors to computers. However, a new standard way had to be developed. Some early standards were proposed but eventually, DVI emerged as the new interface for Digital flat panel LCD monitors and graphics cards. One of the most confusing things about DVI is that there are three different styles of cables and connectors. They are DVI-D: This is the most common style. Almost all DVI-capable devices on the market use a DVI-D interface. DVI-A: In a digital-only world, "DVI Analog" would make no sense. However, as with all new technologies, there needs to be a way to connect to older equipment. DVI-A uses a DVI style connector on a cable that sends an analog-only signal, which can be understood by analog VGA monitors. DVI-I: In practice, DVI Analog-only cables are rare, and DVI Analog devices are non-existent.
The DVI Integrated cables and connectors offer the best of both worlds: a single cable and connector that can transmit both a digital and an analog signal. Since a DVI-I connector offers the most flexibility, video cards such as the ATI Radeon 8500 use this connector so that either a DVI digital screen or VGA monitor can be connected. In DVI an Analog signal will only talk to analog devices, and a Digital signal will only talk to digital devices. Trying to convert a DFP or DVI-D (Digital) signal to a VGA (Analog) signal will never work. Single Link and Dual Link: After all these the difference between DVIs, DVI-D and DVI-I also come in either Single Link or Dual Link. The basic difference is that dual-link can support higher resolutions. Single link cables can be identified as having 8 pins missing, while dual-link cables use 24 pins. Single Link: Can support resolutions up to 1920 x 1080 at 60 Hz. Each link has three data channels for RGB information with a maximum bandwidth of 165 MHz, which is equal to 165 million pixels a second. Uses 12 of 24 pins. This is more than adequate for most plasma TVs. Dual Link: Can support resolutions up to 2048 x 1536 at 60 Hz. Each link has three data channels for RGB information with a maximum bandwidth of 165 MHz, which is equal to 165 million pixels a second. Uses all 24 pins. Most DVI digital devices have connectors that can accept dual link cables but there are a few plasma TVs that can only accept a single link cable. So, it's always good to check with your device retailer about the appropriate cable to choose from. Here you will get more information and differences about DVI cables type https://www.404techsupport.com/2014/08/21/dvi-types/ .
How to repair power supply
It's probably the 'invertor', not the backlight or powersupply. That is assuming that the power-led does turn on ?
2helpful
Alive nf6g - dvi lan problem
Get online and got to www.google.com Inthe google search box type: "Acer Support" (without thequotes). Look for downloads and drivers. Enter your model numberand operating system when requested. Download and install the drivers
I want to connect a PC (VGA connector) to a Hitachi projector TV (channel 1: DVI connection). I want to find out what do I have to change in TV settings (like input type) and how.
Not all DVI inputs are the same. Do you have the manual handy to see if it supports analog DVI?
If it does, you should be able to just use A VGA cable with DVI adapter from your computer to the TV, Select the DVI input on the TV, and make sure your computer display settings are correct (this depends on a few things, so if you need help with that please reply back with more detail about your PC setup)
How can I get rid of The Weather Channel and Ebay Countdown when I open my Window?
Weather Channel and Ebay Countdown are usually on the startup..If you pertaining when you log on to windows then Weather Channel and Ebay Countdown pops up I have the solution for your problem..
You can edit the start up by clicking on start then run, then type msconfig..System Configuration utility will pops up..Search the entries responsible for the Weather Channel and Ebay Countdown..Uncheck those two entries and click on apply then restart the computer..
Another way is by deleting the start up entries of the two items.. Click on start, then click on run, then type regedit.. Registry editor will appear after doin so..Expand computer then 5 hives will appear..expand HKEY Local Machine look for Software..Expand Software and look for Microsoft..Expand Microsoft then look for Windows..Expand Windows and look for CurrentVersion..Expand CurrentVersion and look for RUN..Highlight RUN and check the entries on the left pane..Look for the entries of weather channel and ebay countdown..delete the two and restart pc..
I have an DVI to HDMI cable running to my Playstation 3. The playstation reconizies the connection. When I search the tv for the connection I connot find it.. The back of the tv says the DVI input is...
Did you ever find a solution to this problem? I have the same model TV and I cannot get anything to display from a DVI video source. Anything "pure" HDMI like a DVD player, XBOX 360, or media streamer, work fine. I now have a PC connected to the TV. The PC has an HDMI port and works fine on 2 LCD TVs I have at home but not this one. I'm starting to think it's a wierd HDCP thing.
Esa 42 in plasma.....out of range?
i have a plasma tv (china brand) when i start the TV the remote control for other devices are not working, only working if the remote is too close to the sevices or by reducing the brightness to its minimum level (zero level..no brightnesss)
i need help strange fault
3answers
Comp to dvi problem
there are some settiings on your laptop you need to set specific for tv monitors different dvi format is used
2helpful
4answers
Color screen
If you are hooked up with a DVI cable you need to either use hdmi, component cables or turn off the non hd override...
1helpful
Screen Size
When you are using the DVI connection on this unit it will automatically set the aspect ratio. There is no way to force it into stretching the picture as it will with other input sources. The only way to get to fullscreen would be to go into the setup menu on your cable box and set the "4:3 override" option to one that will meet your satisfaction. I'm having issues with this one skewing the picture to the left on DVI input. I'll crack it open one of these days to see if there are some adjustments that I can mess with on the inside. If there is anything further I figure out, I'll repost.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
