ValuSoft Initial D: Mountain Vengeance for Windows Logo
A
Anonymous Posted on Jul 03, 2010
I'm trying to play initial d mountain vengeance on pc but it won't let me create a profile I can enter my name but when I click done it just jumps back to the empty box where your profile goes
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 06, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
997
Points
Run the game as administrator
Hello my scanner wont work for lexmark x852e. please help
Don't know if you have tried this, but it might help.
Create a scan to PC profile
1 Type the IP address of the MFP in the address line of your browser, and then press Enter.
If the Java applet screen appears, click Yes.
2 Click Scan Profile.
3 Click Create Scan Profile.
4 Select your scan settings, and then click Next.
5 Select a location for saving the scanned output file somewhere on your computer.
6 Enter a profile name.
The profile name is the name that will appear on the Scan Profile list on the MFP control panel.
7 Click Submit.
8 Review the instructions on the Scan to PC screen.
A shortcut number was automatically assigned when you clicked Submit. You can use this shortcut number when
you are ready to scan your documents.
a Go to the MFP, and place your original document in the ADF face up, long edge first.
b Press # followed by the shortcut number on the keypad, or touch Profiles on the home screen.
c After you enter the shortcut number, the scanner will scan and send the document to the directory or
application you specified. If you touch Profiles on the home screen, locate your shortcut on the list.
9 Return to your computer to view your file.
Your output file is saved in the location you specified or launched in the application you specified.
Good luck.
tip
Create a duplicate user profile with a different name
To create a duplicate of an user profile with a different user name, try this:
  • Create a new user account
  • Logon to that account to initialize the newly created profile
  • Log off from the newly created profile
  • Login as built-in Administrator
  • Open Control Panel System applet
  • Click the Advanced tab
  • Click Settings under User Profiles
  • Select a profile to copy from and choose Copy To
  • Browse to the profile to copy to (C:\Documents and Settings\username)
A new profile is now created which is the duplicate of your user profile.
tip
How to copy data from a corrupted user profile to a new profile
This article describes how to copy user data from your Windows XP profile to a new profile.
When you copy user data into a new profile, the new profile becomes a near duplicate of the old profile, and contains the same preferences, appearance, and documents as the old profile. If your old profile is corrupted in some way, you can move the files and settings from the corrupt profile to a new profile.
Note The method that is described in this article may not transfer the Outlook Express e-mail messages and address user data that are associated with the user profile where you are transferring data from. When you delete the old profile, you may delete that data if it you do not first transfer it by using other methods. For more information about transferring Outlook Express user data, click the following article number to view the article in the Microsoft Knowledge Base:
MORE INFORMATION
Create a New User Profile in Windows XP Professional
1. Log on as the Administrator or as a user with administrator credentials.
2. Click Start, and then click Control Panel.
3. Click User Accounts.
4. Click the Advanced tab, and then click Advanced.
5. In the left pane, click the Users folder.
6. On the Action menu, click New User.
7. Enter the appropriate user information, and then click Create.
Create a New User Profile in Windows XP Home Edition
4. Under Pick a task, click Create a new account.
5. Type a name for the user information, and then click Next.
6. Click an account type, and then click Create Account.
Copy Files to the New User Profile
1. Log on as a user other than the user whose profile you are copying files to or from.
2. In Windows Explorer, click Tools, click Folder Options, click the View tab, click Show hidden files and folders, click to clear the Hide protected operating system files check box, and then click OK.
3. Locate the C:\Documents and Settings\Old_Username folder, where C is the drive on which Windows XP is installed, and Old_Username is the name of the profile you want to copy user data from.
4. Press and hold down the CTRL key while you click each file and subfolder in this folder, except the following files: • Ntuser.dat
• Ntuser.dat.log
• Ntuser.ini
5. On the Edit menu, click Copy.
6. Locate the C:\Documents and Settings\New_Username folder, where C is the drive on which Windows XP is installed, and New_Username is the name of the user profile that you created in the "Create a New User Profile" section.
7. On the Edit menu, click Paste.
8. Log off the computer, and then log on as the new user
1helpful
Virtua tennis 4 product key
Think I found something to help you Don't worry much on not having a product key like i did... lol... All you need do is follow the steps a gonna be listing out now Step1: Open the game Step2: Go to sign in-------> create new profile Step3: Scroll down to click on create a local profile and the enter any profile name Step4: Submit and then click on done
1helpful
4answers
I want to change the name on my profile on my mini pc
look at on MyComputer, you must as administrator too do it.
1. right click -> manage
2. find "Local user & Group" -> Users
3. find your name -> Right click "Properties"
4. Type on full name with Your Change New Name.
2answers
When Windows XP tries to load, I get the following message: "We apologize for the inconvenience, but Windows did not start successfully. A recent hardware or software change might have caused this." My...
Try hitting F10 to do a system repair, it should hopefully repair your startup problems. If successful, update your Anti-Virus software and do a complete systems check.
2helpful
I have a cect n97c and i can't seem to get the settings correct in the the phone to be able to send and receive mms. I've called t-mobile 20 times and they finally told me that i needed to contact the...
Create Data Account
3. Select Services
4. Select Data Account
5. Select GPRS
6. Choose an empty profile
7. Account Name enter T-Mobile WAP
8. Press Options
9. Press Done
10. APN enter wap.voicestream.com
11. Press Options
12. Press Done
13. User Name >Leave Blank<
14. Password >Leave Blank<
15. Auth. Type choose Normal
16. Press Done
17. Press Save
T-Mobile MMS
Create Profile
3. Select Services
4. Select WAP
5. Select Setting
6. Select Edit Profile
7. Select a profile
8. Choose Edit Profile
9. Rename Profile enter T-Mobile WAP
10. Homepage enter wap.myvoicestream.com
11. Data Account select GPRS
12. Select T-Mobile WAP
13. Connection Type select HTTP
14. Proxy Address enter 216.155.165.050
15. Port enter 8080
16. User Name >Leave Blank<
17. Password >Leave Blank<
18. Press Done
19. When prompted to SAVE please select Yes
20. Select Activate Profile
21. When prompted to Activate Profile please choose Yes
22. Press Done
Create Data Account
3. Select Services
5. Select GPRS
8. Press Options
9. Press Done
11. Press Options
12. Press Done
16. Press Done
17. Press Save
Create Profile
3. Select Messages
4. Select MMS
5. Select Message Setting
6. Select Server Profile
7. Select a Profile
8. Select Edit Profile
9. Select a profile
10. Choose Edit Profile
11. Rename Profile enter T-Mobile MMS
12. Homepage enter http://216.155.174.84/servlets/mms
13. Press Options
14. Press Done
15. Data Account select GPRS
16. Select T-Mobile WAP
17. Connection Type select HTTP
18. Proxy Address enter 216.155.165.050
19. Port enter 8080
20. User Name >Leave Blank<
21. Password >Leave Blank<
22. Press Done
Reboot your phone
this should work i had the same problem
Mar 12, 2010 • Cell Phones
1helpful
2answers
Nokia phone wont connect to the GPRS
Creating Data Accounts
Steps:
1. Open Services Menu.
2. Open Data Account.
3. Open GPRS.
4. Create/Edit Data Account and enter the following values:
For Globe MMS Data Account:
Account Name: GlobeMMS
APN: mms.globe.com.ph
User Name: leave it blank
Password: leave it blank
Auth. Type: Normal
For Globe GPRS Data Account:
Account Name: GlobeGPRS
APN: http://www.globe.com.ph
Auth. Type: Normal
For Smart MMS Data Account:
Account Name: SmartMMS
APN: mms
Auth. Type: Normal
For Smart GPRS Data Account:
Account Name: SmartGPRS
APN: smart1
Auth. Type: Normal
5. Save the Data Account.
Configuring WAP/GPRS/Internet Services Using the Data Accounts Created
2. Open WAP.
3. Open Settings.
4. Open Edit Profile.
5. Create/Edit a Profile and enter the following values:
For Globe GPRS Profile:
Rename Profile: myGlobe GPRS
Homepage: http://www.globe.com.ph/globe.asp
Data Account: GlobeGPRS (this data account is the one you have created)
Connection Type: HTTP
Proxy Address: 203.177.042.214
Proxy Port: 8080
Username: leave it blank
For Smart GPRS Profile:
Rename Profile: SmartGPRS
Homepage: http://wap.smart.com.ph
Data Account: SmartGPRS (this data account is the one you have created)
Proxy Address: 010.102.061.046
Proxy Port: 8080
6. Save the Profile.
7. Activate the Profile.
8. WAP/GPRS/Internet services now ready to use. In case you encounter errors, double check the Data Account and Profile created. In some cases you need to restart the phone.
Configuring MMS Using the Data Accounts Created
1. Open Messages.
2. Open MMS.
3. Open Message Settings.
4. Open Server Profile.
For Globe MMS Profile:
Rename Profile: GlobeMMS
Homepage: http://192.40.100.22:10021/mmsc
Data Account: GlobeMMS (this data account is the one you have created)
Proxy Address: 192.040.100.020
Proxy Port: 8080
For Smart MMS Profile:
Rename Profile: SmartMMS
Homepage: http://10.102.61.238:8002
Data Account: SmartMMS (this data account is the one you have created)
Proxy Port: 8080
8. MMS services now ready to use. In case you encounter errors, double check the Data Account and Profile created. In some cases you need to restart the phone.
36helpful
9answers
Getting "GPRS NOT SUBSCRIBED" message
Data Account Setup:
From the Main Menu select > Services > Data Account > GPRS
Scroll to an empty account (IE: Account icon_cool.gif and select Edit
Set Account Name to T-Mobile Internet
Set APN to internet2.voicestream.com
Leave Username and Password blank
Press Done
Select Yes to Save
WAP Profile Setup:
From the Main Menu select > Services > WAP > Settings
Select Edit Profile
Scroll to an empty profile (IE: Profile icon_cool.gif and select Edit Profile
Set Profile Name to T-Mobile Internet
Set Homepage to http://www.t-mobile.com
Select Data Account > GPRS > T-Mobile Internet
Set Connection Type to HTTP
Leave Proxy blank
Leave Port blank
Press Done
When Prompted to Save select Yes
Scroll to T-Mobile Internet and select Activate Profile
To Access the Browser:
Select Homepage to bring up the homepage
Select Enter Address to browse other pages
To setup Picture Message (MMS)
Create Data Account
Select Menu
Select Services
Select Data Account
Select GPRS
Press Options
Press Done
Press Options
Press Done
User Name
Password
Press Done
Press Save
Create Profile
Select Menu
Select PIM
Select Messages
Select MMS
Select a Profile
Select Edit Profile
Select a profile
Choose Edit Profile
Press Options
Press Done
Select T-Mobile WAP
Port enter 8080
User Name
Password
Press Done
Activate the profile
1helpful
Iphone clone p168
You need to do some setups for the internet.
For AT&T
Watch the YouTube video on internet setup for AT&T WAP
***First Step***
1.Main menu --> Select Services
3.Select Data Account --> Select GPRS
5.Select the first entry
6.Edit the account name to whatever you would like
7.Edit APN to wap.cingular (lowercase)
8.Edit Username to [email protected] (UPPERCASE)
9.Edit Password to CINGULAR1 (UPPERCASE)
10.Edit Auth Type. to Secure
11. Save
Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
3.Select the first entry --> Edit Profile
5.edit the name to whatever you would like
6.Edit Homepage to http://device.home
7.Edit Data Account to the Name you established in the First Step
8.Edit Connection type to HTTP
9.The IP address is 066.209.011.032 and the port number is 8080
10.Edit Username to [email protected]
11.Edit Password to CINGULAR1
Select back or done
Select Activate Account
You should now see a Black [G] in the upper left of your screen.
MMS
Select Messages --> MMS --> Message Settings
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Home Page to http://mmsc.cingular.com
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080
Edit the Username to [email protected] (UPPERCASE)
Edit the Password to CINGULAR1 (UPPERCASE)
Select Done or Save
Make sure to activate the profile and you are good.
Email will not work with any server that requires smtp authentication (which is pretty much all of them here)
There is no java in the browser. Forget it. There is also no java loader so there is no downloading java games. Copying them to the SD card won't work either. No java loader so the file will be unrecognized.
Wap services like gmail, yahoo email and wap based instant messagers work fine. Make sure you have a good unlimited feature so you do not incur overages from over using your new toy.
For T-mobile:
This is the one that worked for me - I have the $5.99 TMobile Web plan:
Create Data Account
1. Select Menu
2. Select Entertainment
3. Select Services
5. Select GPRS
8. Press Options
9. Press Done
11. Press Options
12. Press Done
16. Press Done
17. Press Save
Create Profile
1. Select Menu
3. Select Services
4. Select WAP
5. Select Setting
7. Select a profile
15. Port enter 8080
18. Press Done
22. Press Done
If you have the $19.99 or higher plan replace the following:
Step 7 under Create Data Account:
Optional - change name from TMobile WAP to TMobile "whatever"
Step 10 under Create Data Account:
use wap.voicestream.com or internet2.voicestream.com or internet3.voicestream.com instead
and
Step 9 under Create Profile:
Step 10 under Create Profile:
change to www.tmobile.com - may not work so try google.com also
SMS, MMS AND VOICEMAIL
1- Click on thee envelope icon it will take you to Messages
CLICK ON SMS
1- Message settings--> click in Profile Setting
2- Click edit on any profile name it T-mobile that will be line No. 1 in No.2 type +12063130004
MMS
1-Message Settings-->click Server Profile
2-Click on any 1--> click on Edit Profile
1- Rename profile
T-mobile MMS
2- Homepage
3-Data Account
click on GPRS--> choose Tmobile--> press OK
4- Connection Type
HTTP
5- Username
leave it blank
6 Password
leave it blank
CLICK ON DONE --> SAVE-->ACTIVATE PROFILE
VOICEMAIL:-
Edit it--> name No.1 Viocemail
No.2 +18056377243
NOTE:
Whenever the phone will ask you for a proxy address and port number.
You need that info to be able to get your sevice to work
Here is that info ...
Proxy: 216.155.165.050
port: 8080
Top ValuSoft Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a ValuSoft Video Game Console and Game Expert? Answer questions, earn points and help others
