CDV Software Cossacks 2: Napoleonic Wars for Windows Logo
Posted on Jul 04, 2010
How to run Cossacks 2 on windows 7 Dear User! This file contains detailed information on the problem occurred. Save the file and forward it to your product Customer Support. ------------------------------ Information ------------------------------ [Error Information] 3.4.65.11; 3002 [Protected Product Information] CompanyName = CDV ProductName = Cossacks II - Napoleonic Wars BuildSignature = 3.04.065.011, 18.03.05 ProductGuid = {bb199558-88e1-ecd7-70cf-f7d928327ff7} BuildGuid = {5495bd64-be60-40ce-99db-76ee9499122d} [Report Information] ReportDateTime = 05 July 2010 00:01 AM ClientTimeZone = South Africa Standard Time ClientTimeBias = -120 [System Information] System Information report written at: 07/05/10 00:00:53 System Name: MAMEYER-PC [System Summary]
Anonymous
Level 1:
New Friend:
  • Contributor 7 Answers
  • Posted on Jul 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
7
Questions
0
Helped
19585
Points
22
Try registering for free at this website http://cossacksworld.ucoz.co.uk/ and click on their downloads folder to see if they have a patch or a workaround for this issue.
tip
A blank Web page is displayed when you start Internet Explorer 7.
Symptom:
loadTOCNode(1, 'symptoms'); When you start Windows Internet Explorer 7, your home page does not open. Instead, a blank Web page is displayed.
Additionally, you may receive an error message that resembles the following:
Line 56
Char:2
Error: Element not found
Code: 0
URL:http://runonce.msn.com/runonce2aspx
This problem typically occurs after you install Internet Explorer 7, after you install Windows, or after you reset Internet Explorer settings. This problem may occur only for certain users.
To have us fix this problem for you, go to the “Fix it for me” section. If you would rather fix this problem yourself, go to the “Let me fix it myself” section.
Cause:
This problem occurs if the Customize Your Settings Web page in Internet Explorer 7 is not loaded correctly or if the Customize Your Settings Web page opens with restricted security settings.
Fix it for me
To fix this problem automatically, click the Fix this problem link. Then click Run in the File Download dialog box, and follow the steps in this wizard.
Fix this problem
Microsoft Fix it 50065
Note: This wizard is temporarily in English only. However, the automatic fix also works for other language versions of Windows.
Note: If you are not on the computer that has the problem, you can save the automatic fix to a flash drive or to a CD, and then you can run it on the computer that has the problem.
To resolve this problem, create and run a Skiprunonce.reg file for each user account that experiences the problem. If you would rather modify the registry directly, see the "Advanced users" section.
To do this, follow these steps:
  1. Start a text editor, such as Notepad.
  2. Copy the following information, paste it into the text editor, and then save the file as Skiprunonce.reg:
    Windows Registry Editor Version 5.00
    [HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main]
    "RunOnceHasShown"=dword:00000001
    "RunOnceComplete"=dword:00000001
  3. Exit the text editor.
  4. Double-click the Skiprunonce.reg file that you created in step 2.
    When you run the Skiprunonce.reg file, you will receive the following message:
    Are you sure you want to add the information in path of .reg file to the registry?
    Click Yes. Then you will receive the following message:
    Information in path of .reg file has been successfully entered into the registry.
Notes:
  • In Windows Vista, when non-administrator users try to run SkipRunOnce.reg they are prompted for an administrator password.
  • To run SkipRunOnce.reg for all users at the same time, modify SkipRunOnce.reg by replacing [HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Main] with [HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main] and then running it as an administrator.
Similar problems and resolutions
To troubleshoot similar problems, self-help steps for beginning to intermediate computer users are available at the following Microsoft Web site:
Troubleshoot problems in which Windows Internet Explorer stops responding or crashes
Note: This Guided Help content may not be available in all languages.
The information in this article applies to:
  • Windows Internet Explorer 7
  • Windows Internet Explorer 8
Keywords: MS Article ID 945385
on Mar 29, 2010 • Computers & Internet
I've installed Cossacks(the Art of War) in Windows 7 Professional. HP-Pavilion Slimline s5710F.The game come up with double vision still can't play,everythink runs together.
I think there is a form of copy protection that installs a driver onto your computer. It was originally designed to be used on Windows XP only. In order to fix this issue, you'll need to contact the game developer for an update or patch that allows you to install the game. There is no other work-around for this, because Starforce contains a driver that Vista will not accept because it is built for another operating system. Starforce protected games are well known to be one of very few XP titles that will not work on Vista without an update or patch, due to its design.
    You can give this a go too... http://m0001.gamecopyworld.com/games/pc_cossacks.shtml
    2answers
    I dont know how to run cossacks eur. wars on win7....how?
    Windows Vista or Windows 7, will have problems running some older versions of applications, just because so much has changed under the hood from Windows XP days. Thankfully there is a compatibility mode that can be easily set per application.
    To configure the compatibility mode for an application, just locate the installation directory and right click on the .exe, selecting Properties from the menu. THEN select your compatibility tab, You can choose to run the program in Windows XP compatibility mode, or even all the way back to Windows 95 compatibility.
    Probably the most useful setting to start off with would be to disable the visual themes and desktop composition, if you can't get things working. If you are trying to run a video game, you will often need to choose "Run this program as an administrator". You'll have to play around with it, but most likely you can get your application working this way. Also, you will be able to make a selection for windows VISTA which is backwards and forwards compatible with WINDOWS 7
    3helpful
    I've installed Cossacks European Wars onto my laptop which has Windows 7. However, when I try to run the game I get a dmcr.exe error. I've looked at solutions online which told me to change 'Video' to...
    1- download a direcx and install it (i put a link for you)
    http://www.softwarepatch.com/windows/directx.html
    if it doesn't work:
    1- go to control panel from start menu.
    2- select windows update.
    3- select check for updates.
    8helpful
    I can't not play cossacks 2 napoleonic wars in windows 7 you have any solution?
    The Game doesn't play because of totally different work environments than it has been designed to. Here are some solutions:
    1. Rename Video folder in the game.
    2. Right click on the program. Then navigate to compatibility, then select the compatibility operating system the game is supposed to be played under. Also, after you select xp sp2 and check the box that says "run as administrator".
    3. Download this patch from:
    http://www.downloadsource.net/v/11290/
    1helpful
    Cossacks runs and comes up with a black screen nothing else and then i closes the black screen and says could not load missions text
    Run the following script (.bat archive):
    taskkill /f /im explorer.exe
    C:
    cd \program files\cossacks
    dmcr.exe
    start explorer.exe
    Save it as batch archive and good luck!!
    1helpful
    I have windows 7 installed on my pc.i installed cossacks II napoleonic wars properly,and when i try to start the game,i get information that the game can run only on older versions on windows (95,98 XP )....
    Well, try this, we call this "compatibility" mode, most programs can be run on windows 7 with this trick.
    I assume your Cossacks II Napoleonic Wars icon is on the Desktop,
    Right-click the Icon (game's icon), select "Properties" and click "Compatibility" tab, select "Run this program in compatibility mode for" click the "Windows 95..." and select "Windows Xp (Service pack 2)", click "Apply" > "Ok" and try again.
    If even after doing this, the game can't be played, then there's no option. The fact is that, this game is made to run on system with Windows xp and earlier version, but somehow if fortunate, it's possible, not will all software, some may work, some may not.
    Good luck.
    Thanks for using FixYa.
    1helpful
    Windows 7 incompatibility
    If you have Windows 7 Ultimate, it comes with a Windows XP mode that allows you to emulate windows xp. If you haven't already tried right clicking the exe or shortcut and clicking the compatibility tab and setting it to windows xp service pack 2 (not 3 for some strange reasons)
    62helpful
    5answers
    Cossacks European Wars on Windows 7
    yo change folder name Video -> video1. You will succeed. :D
    Top CDV Software Video Game Consoles & Games Experts
    MegaByteMe
    MegaByteMe
    Aron
    Are you a CDV Software Video Game Console and Game Expert? Answer questions, earn points and help others
