When i select type of wash i want done the light comes on but nothing happens when i push and hold start, light just blinks maybe a sensor? how can i check have a meter and know how to use it
Open the back on the right side on the bottom panel,you well see lots of wires,NOW START tagging wires uses two people for this.it may be easy to change switch out
I've been going crazy with this too. Turns out all you have to do is hold down the "options" & "select" buttons at the same time until the "lock light" (the light just above the "pause/cancel" button) turns off. I guess that's why there is a line under the option/select buttons that have a lock symbol connecting the two.
Press and hold the control lock button down until the light goes off. This is a child proof feature that may have come on if you leaned against it to long. After lock light goes off you can use the machine.
If I remember correctly you have to move the door boot seal out of the way by removing the wire ring underneath to get inside to the door switch there are two screws holding in the latch on the outside
